Results 1 to 5 of 5
    Aug 2013
    Ohio
    Tachometer issues
    I have a 1992 Laser and I believe I'm having issues with the tach. After shutting the key off the tach will start rising back up. Is it just a wiring issue or is the tach bad itself?
    When I turn my key off my tach goes back up to around 900 sometimes just 700.
    will do it even with the wires off the back.
    mine is omc but I am pretty sure my old merc done the same.
    Mar 2004
    vonore tn.
    It is probably return spring inside tach. If it does that, tach. is probably inaccurate. test tach. in boat, or remove it & take to dealer with tach. tester. some tach,s. it may be normal.
    Both my Merc 10,000rpm tach's stay around what rpm the motor was shut off at.
    [QUOTE=Promax200;2986104]I have a 1992 Laser and I believe I'm having issues with the tach. After shutting the key off the tach will start rising back up. Is it just a wiring issue or is the tach bad itself?[/QUOTE
    With the battery switch off turn the key on/off again and see if it zeros.
  1. OMC Tachometer Help Please
    By BigBrud1958 in forum Technical Discussion
    Last Post: 07-29-2013, 07:44 PM
  2. Best Tachometer
    By bacaruda in forum Technical Discussion
    Last Post: 02-05-2010, 12:45 PM
  3. Tachometer
    By caryon in forum Technical Discussion
    Last Post: 12-08-2004, 12:39 PM
  4. tachometer
    By boatermike in forum General Boating Discussion
    Last Post: 09-03-2004, 07:54 AM
Bob's Machine
