Page 3 of 3 FirstFirst 1 2 3
Results 31 to 36 of 36
Thread: Vking yt setup
  1. #31
    longisland ny lindenhurst
    I been trying to test and compare topend numbers with and without my hatch. Bullet level with the pad 23gal of fuel 3gal of oil and humidity between 84-87%. Only difference was one day was 1mph winds and the other was 3mph winds. With the hatch it runs 111 at 6700 and without the hatch it runs 111 at 6750. My daily driven prop is still the 34 bravo1. It handles alot better with the hatch on it. Now to find a good prop to get my slip down
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  2. Likes capteliminator liked this post
  3. #32
    Next prop to be tried will be a 14 5/8 x 35p 4blade buckshot cleaver. Hope it will run good. I might need a 15dia but this is a starting point. A 14 7/8 x 34p 3blade ran 102 on the limiter so this 4blade should help i hope.
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  4. #33
    Jun 2018
    Floating around
    This is one awesome rig. I have watched some of those vids of yours at least ten times, even my wife likes watching them. Looking forward to your results with the new prop
  5. Thanks 16ft superboat thanked for this post
  6. #34
    Thank you. I have 2 props to try before the boat gets wrapped up in December. For now its the 4blade cleaver.
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  7. #35
    The buckshot 4blade ran real well. Pulled just as fast if not faster then the merc 34 3blade. Due to the extra blade the cleaver had to much stern lift and would cause the bow to dive down around 100.
    This weekend i also tried a 31p 5blade cutting edge prop. Loaded up alittle in the beginning but once it broke loose it was a sling shot. Ran good and got a top speed at 97 with a full tank and 2 people.
    Next and final prop is the modified 36p bravo. Will be running that in the up coming weeks
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  8. #36
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  1. vking setup
    By bigbluechevy454 in forum Props, Setup, and Rigging
    Last Post: 05-31-2010, 06:27 PM
  2. hydrostream vking setup
    Last Post: 05-17-2010, 07:49 PM
  3. Hydrostream Vking Setup Evinrude 175
    By FenceDawg in forum Technical Discussion
    Last Post: 05-18-2009, 07:09 PM
  4. Hydrostream Vking Setup
    Last Post: 05-11-2009, 07:38 PM
  5. setup for vking yt ??
    By tblotske in forum Props, Setup, and Rigging
    Last Post: 10-19-2006, 05:30 PM
