Results 1 to 3 of 3
09-08-2017, 09:16 AM #1
45° degree angle on stainless bolt on cav plate or straight...stv euro
Can some clear the air for me... I've seen both type of bolt on cavitation plates, 1 straight and 1 with 45 degree bent wings at the ends, going to bolt 1 onto my stv euro, i have the straight plate, what is the point to having the ends bent... should i leave it straight or bend the plate? Will be used for drag racing and lake cruising. Thanks
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
09-08-2017, 09:59 AM #2
The bent down wings create more pressure/lift than a flat plate.
RockTeam Junk
09-08-2017, 04:38 PM #3
Makes sense... thanks rock! Guess I'll be chucking the plate in the old bend press!
45° degree angle on stainless bolt on cab plate or straight...stv euro
By Brookbbb in forum Technical DiscussionReplies: 0Last Post: 09-06-2017, 09:44 AM -
Bolt on cav plate and/or bottom plate on jack plate for an STV Euro
By Brookbbb in forum Props, Setup, and RiggingReplies: 9Last Post: 03-17-2017, 12:26 AM -
merc heads 2 Degree angle to help eliminate pinch
By eli in forum Technical DiscussionReplies: 8Last Post: 11-02-2016, 09:52 PM -
Specific Angle Area Degree
By FMP in forum General Boating DiscussionReplies: 20Last Post: 04-13-2015, 05:00 PM -
Need to cut a 4.5" hole through my dash at a 20 degree angle.
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 16Last Post: 07-08-2010, 09:01 PM
