Results 1 to 4 of 4
    Jul 2014
    MN
    Need Prop help/ Advise
    I have a 1977 Glastron CV-23. The boat is fully restored and I just got it on the water a month ago.
    I have a 383 SBC with about 360 HP and 405 in torq. I am running a Alpha Gen 2 drive 1.47 gear. I have blueprinted the bottom of the boat and removed all the hook, sharpened strakes and the transom. I also raised the X-dimension by 2 inches. The boat is a v-hull with a pad that is about 2 ft wide at the back. The cavitation plate on the boat is about a half inch above the transom edge when trimmed down. The boat loaded and with fuel is probably around 22- 2400lbs
    Props I have tried are
    23P Turbo 3 blade. This was not even close to enough prop.
    25P 4 blade Powertech TRO small diameter. I was at about 5800 RPM and 64.3 MPH(GPS)
    Next 25P 4 blade Rev4 This gave me 67.3 and about 5,600 rpm
    Next a Hydromotive 4 blade 25P This got me to 68.4 and still about 5600 rpm.
    With the last 2 I had a good hole shot, felt great and drove nice. Putting these numbers threw a slip calculator I am at about 23% slip give or take depending on the prop. I am pretty sure I will need a surface prop like the hydromotive. Thinking I will probably have to go to a 27p and have the blade cupped to drop down my rpms
    I would like to be closer to the 5100 rpm just to keep from spinning the drive to fast.
    Anyone have any thoughts or suggestions on props to try? There really are not any shops around me that I have found(Minneapolis area) that have really anything over a 23p. I will probably be buying some props from here or eBay to get what I need.
    Thoughts? Suggestions?
    Thanks
    Jun 2013
    Minnesota
    I don't have experience with your setup but try Formula propeller in Minneapolis.
    Jul 2014
    MN
    Anyone have any other thoughts on props to try?
    North Tonawanda, NY
    How about a Bravo 1 in 26 or 28 pitch? It's a large diameter 4 blade and from your testing it appears your rig likes this type of prop.
    Doug
  1. Prop advise
    By Chrisschuh1 in forum Props, Setup, and Rigging
    Last Post: 06-16-2016, 01:30 PM
  2. need prop advise if possible
    By bobkyle2 in forum Props, Setup, and Rigging
    Last Post: 09-21-2010, 04:13 AM
  3. Prop advise
    By 1 Tuff 69 in forum Props, Setup, and Rigging
    Last Post: 07-12-2008, 11:54 AM
  4. Need advise on prop
    By mwillis2003 in forum Props, Setup, and Rigging
    Last Post: 09-13-2006, 07:40 PM
  5. prop advise.
    By action20 in forum General Boating Discussion
    Last Post: 12-22-2004, 11:32 AM
