Results 1 to 2 of 2
09-04-2017, 02:59 PM #1
1994 Yamaha Pro V 175 ....bought a 225HP 1994 Yamaha Parts motor ..compatible parts?
Hi,
I have a great running 175 Pro V on my Vegas XT and it runs perfect. I love the stock reliability of a Yamaha. I found a parts motor in CT about 1hr 40 min from my house and was hoping I could bolt in the intake w read cage and carbs and it would be close to a 225HP stock .
I see the following parts are also different
Tuner
CD Ignition ( this one has a different part # for a 25 in counter rotating motor as opposed to the 20 inch right hand rotation)
Intake
Carbs
Here is another one.....it looks like the 150, 175 and 200 pro V have the same block and the 225 HP is slightly different, I assume large exhaust and intake porting perhaps ?? Does anyone know if that intake will choke up my 175 block if I change over the tuner ? should I change over w the 225 Hp ignition as well ? why is the part # different for CD ignition on a RH vs LH rotation ??
I would love to get to a 200HP + but maintain stock reliability. ....regardless I think I will go w a HydrpoTec Tuner and Reeds while I am at it, but if I just went the stock for stock swap out would it run OK ? I plan on having all the carbs rebuilt as I do not know the deal w them.
any info is greatly appreciated. I would pay for tech advice as well.....I am not sure of the rules on this , I just want to be fair to whomever helps me I would happily pay for the expertise / advice.Scott Strang
Present:
1987 Hydrostream Vegas XT
175 HP Yamaha Pro V
225HP Yamaha 2.6 (Just Bought, can't wait to put together and run! )
Past
1987 Valero YT Bowrider
1994 Pro V 175 Yamaha
Recently deceased:
19 foot Action Marine
225 Evinrude Vindicator
245 HP Carb 2.5 Merc
1984 Hydrostream Vector
2.4 Merc Bridgeport Carb
09-04-2017, 04:31 PM #2
Part #'s so far: Trying to figure out differences and compatibility :
My Motor 1994 175HP Pro V:
Model P175TLR
Tuner Part # 6G5-41132-00-5B Pro V 150 Reg 150HP : 6G5-41132-00-5B Pro V 200 6J9-41132-00-5B Excel : 6G5-41131-01-CA ← 6G5-41131-00-5B
Muffler : 6E5-14711-01-CA ← 6E5-14711-00-5B
Damper Muffler: 6E5-14737-00-00
175HP Reg 175 HP 6G5-41132-00-5B Pro V 200HP 6J9-41132-00-5B Reg 200 HP 6G5-41132-00-5B
Carbs #: 62H-14301-00-00, 62H-14302-00-00, 62H-14303-00-00 Excel 6K7-14301-02-00, 6K7-14302-02-00, 6K7-14303-02-00
CDI: 62H-85540-00-00 Pro V 175
62H-85540-00-00 150HP Ignition
62H-85540-00-00 Pro V 200
Intake #: 6G5-13641-11-1S 61H-13641-00-94 6G5-13641-11-1S
Reeds Assemb # : 6K7-13610-00-00 ProV175 Pro 150and 200HP (not a typo) 61H-13610-01-00
Crank Case Assembly# : 62H-15100-00-94 175 and 150 Pro V
Heads : 6G4-11111-02-1S ← 6G4-11111-02-94 n(ProV150 and 175) 6R5-11111-01-1S ← 6R5-11111-01-94 (ProV 200)
Parts Motor: 1994 225 HP Long Shaft 25 inch , LH or Counter Rotation
Model: L225TXRS 62
Heads : 62J-11111-00-1S ← 62J-11111-00-94
Block: 62J-15100-01-94 ← 62J-15100-00-94
Carbs: 62J-14100-00-00, 14101, 14102
and 62J-14301-00-00 , 14302, 14303
Tuner: 61A-41132-00-5B
Muffler: 61A-14711-22-5B ← 61A-14711-21-5B
Damper Muffler: 6E5-14737-00-00Scott Strang
Present:
175 HP Yamaha Pro V
Past
Recently deceased:
WTB/Need 1994-1995 yamaha shift cam.
By simplyorange in forum Lower UnitsReplies: 0Last Post: 07-27-2015, 09:38 PM -
1994 yamaha pro-v mods
By 79Jcraft in forum Technical DiscussionReplies: 3Last Post: 09-09-2013, 03:46 PM -
Yamaha digital tach dip switch settings for 1994 yamaha C85hp?? 6 or 12 pole?
By syclone01 in forum Technical DiscussionReplies: 0Last Post: 05-02-2011, 09:06 AM -
1994 150 200 yamaha difference
By lulu2 in forum Technical DiscussionReplies: 6Last Post: 11-20-2006, 07:22 PM
