Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 119
  1. #31
    Aug 2017
    Grand Cayman
    Diamond always makes everything into a work of art. We’re actually going to do a full feature on that intake. I”m always happy to see Diamond doing what they do best, which is, make everything uniquely their own creation. Those guys take attention to detail to insane extremes!
    Yep, those guys are awesome. Glad to hear you’re doing an article on their manifold. They’ve been real tight lipped about it. Marty’s been telling me the past 2 years that it was going to be awesome, but that was about all I could get out of him. The PH was built from March of last year, but I decided to leave it up there with them until they got the manifold done, so I could dyno it. I haven’t seen the motor in person since they’ve put the manifold and new heads and flywheel on it. Just from the picture it sure looks a lot better than the dusty, rusty lump I sent them. Everything in this motor is new, except the crank and block.
  2. Likes tux974 liked this post
  3. #32
    That is for sure! Marty and Joe are amazing in what ever they do!
    Look forward to the feature on it.
  4. Likes CI STV liked this post
  5. #33
    lost in Tennessee
    As for the windshield you can call Jack and get him to send some or call Pro Glass @ 630-553-3141 for preformed lexan so you shouldn’t have any distortion in the curves
  6. Thanks CI STV thanked for this post
  7. #34
    Florida Keys
    Georgia boys and your pecans wtf
    '95 STV "The Blue Goose"
  8. Likes CI STV liked this post
  9. #35
    lost in Tennessee
    Lmao, autocorrect ftl
    I’ll make adjustments
  10. #36
    Aug 2017
    Grand Cayman
    Thought I would resurrect this thread now, and report my progress with this project going forward, since I’ve been posting queries about random things all over the forums.
    Heres the jackplate I’m using, created from a 20 year old one off a friends old Triad, cut down to 3” setback. Great thing about it is that it only weighs 10lbs:
ID:	472201Click image for larger version.
ID:	472202Click image for larger version.
  11. #37
    Aug 2017
    Grand Cayman
    I know that mach351 said a while ago (at post #6) that 1.25-1.375” above the pad is optimum height for river running, but what would be the optimum height for drag racing with only 3” of additional setback? ? Or should I set it at about that height with the motor jacked up all the way (I have a 12” mid with the hydraulic up/down) and then launch it with the motor in the full down position and then jack it up as it comes on plane?
  12. #38
    Florida Keys
    It might want a touch lower....but maybe not. Run it and see. Easy enough to change. I want to say Andy Driver was running his at 1.375 and he was on the transom. Jack would know....he drilled the holes.
  13. Thanks CI STV thanked for this post
  14. #39
    Jul 2012
    Lufkin, Texas
    I think that only you can answer that question with testing and a good water pressure gauge...
  15. Thanks CI STV, Kcraft thanked for this post
  16. #40
    Aug 2017
    Grand Cayman
    Thanks guys. I intend to dial it in myself, but just wanted an idea of where to start. I think I’ll set it up at 1.25” above the pad to start and see how that works and go from there.
  17. Likes nitro_rat liked this post
  18. #41
    Aug 2017
    Grand Cayman
    Got a bunch of goodies from Power Performance yesterday. Hopefully I can figure out where it all goes.
    Still waiting on a few bits and pieces, and I need to pull all the old wiring, trim pump etc. out of the boat, but will soon be able to start putting it back together. Will be running an AiM MXL2 Datalogger dash, so that I don’t have to guess what’s going on after a pass.
ID:	472679Click image for larger version.
ID:	472680Click image for larger version.
  19. #42
    PARADISE /Naples
    So what is the second picture ? 12"
    Did you get a flywheel?
  20. #43
    Apr 2007
    Big Pine Key, Fl
    Quote Originally Posted by CUDA View Post
    Trim stop,I got mine to late...
  21. #44
    PARADISE /Naples
    You Funny I did not see it but I heard you roll well,
    I had a Galen B version... good Idea
  22. #45
    Aug 2017
    Grand Cayman
    That’s a trim limit switch. Pretty ingenious device. Didn’t come with any instructions, but I’m sure I can figure it out. I’m going to route the up trim solenoid wires through the switch, connect the trim indicator cable to the slide and adjust the cable and slide so that when the motor reaches the max trim I want it at, it shuts the power off to the solenoid. Im going to use a digital delay to trigger the trim pumps to trim out and jack up on the launch, with this acting as a fail safe.
    It looks like Brendan made some changes to the design compared to the one shown on his website.
    The motor already had a Diamond flywheel on it when I got it back from them. A friend of mine here has one of Brendan’s flywheels though, and it looks real nice.
  1. Pole setting Mercury 2.5 200 Tach setting??
    By SAMMYBOY in forum Technical Discussion
    Last Post: 07-23-2005, 12:20 AM
  2. TPS setting 95 PRO-MAX ???
    By RSM in forum Technical Discussion
    Last Post: 05-27-2005, 07:32 AM
  3. Tps Setting
    By Dark Allison in forum Technical Discussion
    Last Post: 08-03-2003, 12:45 PM
  4. ECU Box Setting
    By Stv Euro in forum Technical Discussion
    Last Post: 03-18-2003, 12:42 AM
  5. Need help setting up my new STV!!
    By CJ in forum Technical Discussion
    Last Post: 06-20-2002, 08:35 AM
