Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 119
    Feb 2005
    Muskoka Canada
    Wht Eric said. Don't mess with the block, don't cut it don't grind it don't stuff it! Put good parts in it and set it up right!
    2023 TUFF 25
  2. Thanks CI STV thanked for this post
    Likes mach351, Chummy, wtsjr66 liked this post
  3. #17
    Aug 2017
    Grand Cayman
    Quote Originally Posted by patchesII View Post
    Not knocking Jay but I'd leave it stock. Factory Drag's from Mercury are really good and capable of winning at the races in any modified class
    I wasn't thinking so much of hogging out the ports as lightening the reciprocating assembly and doing the angle cut on the intake etc. But stock Drag P/H mightn't cut it for me.
    My last rig was a lightweight Mirage RR with a Drag powerhead with 21cc heads, Diamond flywheel and Brucato Intake, on an F1 mid, so I know what they're capable of. But, that rig is now owned by a very tricky friend of mine, who's going to be my competition, along with a built-to-the-hilt, heavily modified Diamond Marine built Drag motor on a lightweight Allison, that's owned by the most resourceful boat racer I can think of. Not to mention S&F member Jerremy Powery (aka "Cayman's Dave Bush") with his OMC powered Quartershot. And Jeremy's a certified OMC mechanic (not to mention a certifiable OMC fanatic ).
    So, I'm just trying to make sure I'm competitive, because we don't have classes here - it's a run-what-you-brung kind of deal - and these guys aren't playing...
  4. #18
    Jan 2003
    cayman islands
    So, I'm just trying to make sure I'm competitive, because we don't have classes here - it's a run-what-you-brung kind of deal - and these guys aren't playing...[/QUOTE]
    Sammy not to worry I need to put my hull on a major diet or add a lot of NOS to the Johnrude before I cause any problems for you Drag Merc guys, I plan on changing the hull when I can afford to get something much lighter to be competitive with you guys. I just wish I still had my Burgess tunnel..
  5. Likes CI STV liked this post
  6. #19
    Aug 2017
    Grand Cayman
    Sammy not to worry I need to put my hull on a major diet or add a lot of NOS to the Johnrude before I cause any problems for you Drag Merc guys, I plan on changing the hull when I can afford to get something much lighter to be competitive with you guys. I just wish I still had my Burgess tunnel..[/QUOTE]
    Haha. Yeah, yeah, yeah. I bet you got some oceanfront property in North Dakota to sell me too, right?
    Try pitching that somewhere else, old friend. I know you!
  7. #20
    Jan 2003
    cayman islands
    Quote Originally Posted by CI STV View Post
    Try pitching that somewhere else, old friend. I know you![/QUOTE]
    No but I have a parcel of land on the Bluff I would sell you.....
    All jokes aside my Q-shot is a Super Sport layup, Jack himself told me the boat is in the 800 Lbs range bare hull and that's who built the boat so anyone can check with him if there is any doubts about what I'm saying. I can walk anywhere on the deck from the drivers seat all the way back to the transom and not worry about going thru the deck, The STV RR for sure can't do that or the Mirage you owned before...
  8. #21
    Aug 2017
    Grand Cayman
    Quote Originally Posted by jerremy powery View Post
    All jokes aside my Q-shot is a Super Sport layup, Jack himself told me the boat is in the 800 Lbs range bare hull and that's who built the boat so anyone can check with him if there is any doubts about what I'm saying. I can walk anywhere on the deck from the drivers seat all the way back to the transom and not worry about going thru the deck, The STV RR for sure can't do that or the Mirage you owned before...[/QUOTE]
    Im just yanking your chain jerremy. I dont doubt what you're saying. The deck in the STV is pretty damn thin, even though Dale had Monty reinforce it a bit when he bought it. I would actually gladly trade off some weight for a stiffer deck, because if I break down I can't even walk back there to the motor to check anything. I was thinking that I might try to at rig the Mod-VP cowling so that it hooks in the back and then uses the bungees in the front, so that if anything, I can pull that off from the cockpit and then walk back through the center of the boat to get to the motor.
    BTW: where you been? I can't say the last time I've seen you, which is pretty bad for living on an island this size...
  9. #22
    Aug 2017
    Grand Cayman
    Just to update this thread, I recently acquired a stock 2000 Drag powerhead that a friend of mine had sitting in storage for over 12 years. It only had a couple of hours of running on it. I’m going to send it up to Diamond for them to pull it down and check the bores, and replace anything that needs replacing. I also have an F1 12” midsection with the hydraulic up/down function and an XR6 lower with a Bobs Bigfoot (I think) that was originally done by JC’s I believe. The mid and lower came off of a DR-20 that my friend had that caught fire and burned down. It was the Larry Smith’s old APBA hall of fame hull, actually. So, I believe that I might have most of the parts I need to make myself a pretty radical STV Mod-VP setup. I still need to get a lots of bits and pieces like the steering wings, cowling, etc. any recommendation on those things would be greatly appreciated.
    I see that both Bobs and Barsh offers aftermarket cowls, so wondering if anyone on here has had experience with those?
  10. Likes Capt.Insane-o liked this post
  11. #23
    Sarasota, FL
    Niether Jack Barsh or Bobs makes cowls anymore as Ive been told
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  12. Thanks CI STV thanked for this post
  13. #24
    Aug 2017
    Grand Cayman
    Man, that sucks. So, the only option is an OEM Merc cowl?
  14. #25
    Not sure if he can help out with the cowl...
    https://www.facebook.com/performancecowls/
  15. Thanks CI STV thanked for this post
  16. #26
    Aug 2017
    Grand Cayman
    Thanks very much for this. Greatly appreciated!
  17. #27
    Aug 2017
    Grand Cayman
    Finally, after a very long wait, my motor is on the dyno at Diamond Marine, waiting to be tested. Check out the sexy new Diamond intake. Can’t wait to see if it runs as good as it looks.
  18. #28
    MIAMI FLORIDA
    Motors looking good..Since you can use your old windshield for a template just buy a piece of polycarbonate sheet and cut one out it will make the bend, I used tinted makrolon .118 thick.
  19. Thanks CI STV thanked for this post
  20. #29
    Aug 2017
    Grand Cayman
    Quote Originally Posted by H2OPERF View Post
    Thanks man. I need to start working on this project soon. Got lots to do to get it where I want it to be.
    Got some good news from Marty earlier today that the motor dynoed at 359hp at 8700 on Diamond’ dyno, and made over 350 from 8200 past 9000 rpm. Not sure what heads he has on it right now though. I wanted some ~19cc heads on it, since I only intend to drag race it on race gas.
    just looked at his email again and it looks like they ceramic coated my heads as well. These guys are true masters.
  21. Likes Scream And Fly liked this post
  22. #30
    Diamond always makes everything into a work of art. We’re actually going to do a full feature on that intake. I”m always happy to see Diamond doing what they do best, which is, make everything uniquely their own creation. Those guys take attention to detail to insane extremes!
  23. Thanks CI STV thanked for this post
    Likes CI STV, tux974, stoker2001, MIKEF18 liked this post
  1. Pole setting Mercury 2.5 200 Tach setting??
    By SAMMYBOY in forum Technical Discussion
    Last Post: 07-23-2005, 12:20 AM
  2. TPS setting 95 PRO-MAX ???
    By RSM in forum Technical Discussion
    Last Post: 05-27-2005, 07:32 AM
  3. Tps Setting
    By Dark Allison in forum Technical Discussion
    Last Post: 08-03-2003, 12:45 PM
  4. ECU Box Setting
    By Stv Euro in forum Technical Discussion
    Last Post: 03-18-2003, 12:42 AM
  5. Need help setting up my new STV!!
    By CJ in forum Technical Discussion
    Last Post: 06-20-2002, 08:35 AM
