Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 15 of 119
    Aug 2017
    Grand Cayman
    Setting up STV Mod-VP
    So, I picked up my recently acquired STV hull today. It's the hull that Monty used to race after he sold me his Mirage way back when, before he switched to the white Triad.
    Over the coming months, I'm going to be setting it up, most likely with a 2.5 Drag powerhead on a 12" mid.
    I intend to go right through it and replace all of the cable steering hardware, fuel cell/system, gauges, etc. and set it up for recreation/drag racing.
    I've been out of the outboard scene for many years now, and I see that it's becoming increasingly harder to find parts and get any advice for 2 stroke outboards, except for here on S&F, so any advice on setup would be greatly appreciated. The good news is that it looks like there's a lot of badass STVs on here.
    Thanks in advance for any helpful tips.
    Sarasota, FL
    Sweet. My advice would be go with a 280 with 260-drag elctronics over the drag if ya wanna keep cost down. You can add SVS and higher compression heads and be very close to a drag. Also would bolt motor straight to the transom. No jack plate. Best CG on that hull no more added setback. The set back is already built into the hull. Bolt it high as you can and still get water pressure. Get a shiftable 12" mid and sportmaster case. With the MOD VP deck that you have I would mount the fuel cell more forward than closer to the transom like a typical River rocket design.
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  3. Thanks CI STV thanked for this post
    Likes mach351, Laser LTV liked this post
    Florida Keys
    What Rob said
    '95 STV "The Blue Goose"
  5. Thanks CI STV thanked for this post
    Likes Laser LTV liked this post
    Aug 2017
    Grand Cayman
    Quote Originally Posted by Hot Shot Merc View Post
    Thanks Rob. That's the kind of info I'm looking for. I was thinking of using a lightweight adjustable 4-6" setback plate, just so that I can move the engine up and down easier to get it to the optimum x-dimension. I'm pretty heavy myself, so I figure that it will still be okay in terms of balance, lol.
    I will mount the cell and battery as far forward as possible though.
    I'll also need to get the necessary adaptor plate to bolt the 12" mid to the Sportmaster lower. Does anyone know who makes these things nowadays?
    I'll also need to get the steering wings for the 12" mid, which I see Mercury are still selling. Are there other options for those?
    I also need to know if there's any other option for the steering pulleys/hardware, other than the Nydahl stuff from Baker (if those are still even available)?
    The boat also needs a new windshield and side windows, as the plexiglas is yellowed and cracked. Does anyone still offer these parts for the Mod VP?
    Thanks again!
    Sarasota, FL
    Jack Barsh at Full Throttle Powerboats can make you a windshield. I think Caldwell Racing Technologies makes the adapter for the 12" to sportmaster not sure tho. I know Ive seen them but forgot who. A few guys run them in ODBA and DSRA.
    String steering: Not sure if these systems are only for smaller outboards or not but heres a link to look into
    http://www.portagebaysystems.com/marine.html
    Rob Lankford
  8. Thanks CI STV thanked for this post
    Florida Keys
    I'd stay away from a 6" plate if possible. A 4" would be the largest, transom mount would be optimum for sure. We figure out which two mount holes on the mid are closest and then slot between the two to give you some adjustment room. Usually 1.25"-1.375" above seems to be the sweet spot for river running.
  10. Thanks CI STV thanked for this post
    Likes DangerNewb liked this post
  11. #7
    Sarasota, FL
    Quote Originally Posted by mach351 View Post
    Agreed. However if you must go with a plate Bobs makes a 2.5" convertable manual jack plate thats rated for 300 hp.
    http://www.bobsmachine.com/Convertab...100-205100.htm
    Rob Lankford
  12. Thanks CI STV thanked for this post
  13. #8
    Aug 2017
    Grand Cayman
    Thanks guys. I really appreciate the guidance here.
    This is what I found on the cable/pulley steering.
    http://www.corboatracing.com/downloa...race-boats.pdf
    Baker has been around forever, I remember getting stuff from them for my old OMC/Action Marine rig years ago. I'll check to see if I can get what I need from them. I know I've seen fancier powder-coated hardware on the high-end rigs in ODBA. Just don't know who made them and if those are still available?
    I'm hoping to go to look at a 2.5 powerhead today. It's apparently seized from sitting for years, but was a low hour motor. Hopefully, all it needs is some new bearings. May send it to JSRE or Diamond to get them to go through it and make it a beast.
  14. Likes DangerNewb liked this post
  15. #9
    Aug 2017
    Grand Cayman
    Thanks Rob. That looks like it would make life easy for me. Hopefully, it can handle more than 300hp from a 2.5, because I intend to build a max effort motor.
  16. #10
    Don't know if you Facebook but this gentleman might be able to take care of some of the needs. Pretty high end stuff but quality..
    https://www.facebook.com/profile.php...9%3A1504456151
  17. Thanks CI STV thanked for this post
  18. #11
    Aug 2017
    Grand Cayman
    Thanks! I don't do Facebook, but I do seem to recall this Geiger Tec name though. I'll check it out.
  19. #12
    Louisiana, MO
    Wintech Engine and Machine, have the cable-pulley system, and I had my wing plates made specifically for my river rocket. Give Nick a call. Their number is 262-662-0892.
  20. Thanks CI STV thanked for this post
  21. #13
    Aug 2017
    Grand Cayman
    Quote Originally Posted by Mo River Rat View Post
    Thanks. You guys are the best.
  22. #14
    Aug 2017
    Grand Cayman
    BTW: I've located a stock Drag powerhead with low hours, but the crank bearings are seized from the powerhead sitting in storage for years. Hopefully the crank is still good and the pistons rings aren't stuck to the bore. My thinking is that I should send this to JSRE and have Jay pull it down and work his magic on it and replace whatever needs to be replaced. I want to squeeze as much power as I can out of this thing.
  23. Likes Mo River Rat liked this post
  24. #15
    shreveport,la
    Not knocking Jay but I'd leave it stock. Factory Drag's from Mercury are really good and capable of winning at the races in any modified class
    Erik Kiser
  25. Thanks CI STV thanked for this post
    Likes mach351, 90 5.0, Chummy, stoker2001 liked this post
  1. Pole setting Mercury 2.5 200 Tach setting??
    By SAMMYBOY in forum Technical Discussion
    Last Post: 07-23-2005, 12:20 AM
  2. TPS setting 95 PRO-MAX ???
    By RSM in forum Technical Discussion
    Last Post: 05-27-2005, 07:32 AM
  3. Tps Setting
    By Dark Allison in forum Technical Discussion
    Last Post: 08-03-2003, 12:45 PM
  4. ECU Box Setting
    By Stv Euro in forum Technical Discussion
    Last Post: 03-18-2003, 12:42 AM
  5. Need help setting up my new STV!!
    By CJ in forum Technical Discussion
    Last Post: 06-20-2002, 08:35 AM
