Results 1 to 12 of 12
Thread: Repaint Cowl
    Aug 2016
    Minnesota
    Repaint Cowl
    I want to repaint a 1995 mercury black max cowl. Is their a paint stripper I could use that would be safe on that?
    I have found the sticker set and im assuming google has the paint code
    1995 ProCraft SuperPro 180 / Mercury 150 XRI
    1997 ProCraft SuperPro 200 / Mercury 225 3L
    Mar 2015
    DFW
    Paint is Phantom Black isn't it?
    As for stripper I'm not sure on that, just sand it?
    Jun 2014
    Canada
    Phantom Black is correct as the previous poster mentioned. Why do you want to strip it? It's easier to sand it and use the original paint as your base layer.
    Aug 2016
    Minnesota
    I just thought it sounded easier to strip it. I will get the heat gun out and try and take the stickers off and then sand it though... Seems thats what is recommended.
    Quote Originally Posted by gguertin145 View Post
    Have done a lot of cowls. Be very careful with the heat gun on the decals as if you get the cowl too hot the paint starts bubbling and then the fun has begun! I always use low wattage on the gun. JMO
    Gary
  6. Likes ctobias1984 liked this post
    Aug 2016
    Minnesota
    Great info thanks!
    use the wife's blow dryer
  9. #8
    I live in Prineville Oregon which is in the central part of the state
    Don't use a stripper you will melt the plastic, Just sand carefully and use Dupont Imron black and you will never regret it, ever.
    Carter Powell
  10. #9
    35 Post(s)
    DuPont Centari 99 is just as tough as Imron and not as toxic. Restored a lot of Mercs with it. Phantom Black is a lacquer based wimp.
  11. #10
    Jun 2018
    Floating around
    Imron aint imron no more. Its polyurethane now
  12. #11
    35 Post(s)
    DuPont's Formula Switch
    Imron used to be polyicocyanate. When did it change to polyurethane? I remember when Imron labels specified Niosh 95 masks, then something else and then finally full-up air fed suits. Used to watch these guys come into the paint store to buy Imron with dust masks on. They're all dead now.
  13. #12
    Jun 2018
    Floating around
    I dont know when the switch happened but i went to buy some and found out its no longer what it was. Its basically awl grip etc all the same a super hard polyurethane epoxy now.
    yep iso, all the good paint was iso. My camaro is in iso, still looks like fresh paint 25 years later
  1. Need To Remove Repaint Down To Gel Coat
    By INXS in forum Appearance Mods
    Last Post: 07-15-2010, 09:39 PM
  2. Removing outboard corrosion for repaint
    By twright55 in forum Technical Discussion
    Last Post: 06-18-2010, 09:34 PM
  3. repaint lower unit
    By R.I.P. in forum General Boating Discussion
    Last Post: 07-29-2008, 10:30 AM
  4. who can repaint my boat?
    By lowlifeAE21 in forum Technical Discussion
    Last Post: 04-08-2007, 09:03 PM
  5. 1985 Hydrostream Vector repaint ???
    By WSJR1 in forum Fiberglass and Composites Discussion
    Last Post: 06-18-2005, 08:13 AM
