Results 1 to 15 of 21
    Apr 2017
    Stock sportmaster vs Bobs machine shop mod
    Hello, I am putting the final touches on my Stroker Bass Boat project, and changing out my lower unit is next i believe, I am running a 250sx with a Torque master gen 2 gearcase, I am considering a Sportmaster or I have been told a Bobs machine Shop conversion is a good alternative, just as fast at fraction of cost. the gen 2 tops out at around 80, but also blows out, not alot of fun at that speed.
    Jul 2012
    Lufkin, Texas
    Coned torquemaster is supposed to be better than sporty (on a v-bottom). Not sure what Bob's backlog is, but mine has held up well for years (not torquemaster but Bob's coned back in the 90's)!
    Josh Peterson
    My coned torquemaster runs much better on my superboat than my sporty did.
  4. Likes nitro_rat, TEXAS20225 liked this post
    My coned TM also ran better, faster and with better control then my Sportie on my 21 RS with a 300PM.
    Do keep in mind that every boat or setup will like and respond differently to lower units, engine heights and props. Even if they are similar to someone else's setup.
  6. Likes Cervelo777, TEXAS20225 liked this post
    I always figured the big skeg on the sportys was the problem. Just more drag.
    Sep 2006
    Bossier City, La
    On the Stroker when you have a trolling motor it is better to run a sporty. It will blow out with a coned unit like the bobs combo. You have to realize that on a Stroker you will be running engine heights in the 2 to 3.5 in above the pad range to attain your best speeds.
  9. Likes nitro_rat, wbooth liked this post
    So you need the bigger skeg in that application. Gear case won't matter since the skeg is the only thing in the water at that height.
    Sep 2006
    Bossier City, La
    Yes Stroker run some extremely high engine heights.
    Sep 2006
    Bossier City, La
    This video gives a some great shots of the gearcase on a Stroker while running at speed.
    https://youtu.be/qO_iBtcVs2w
  13. Likes Capt.Insane-o liked this post
    Waters high now you can run the air boat trails out to monkey box etc....Cool vid and really moving. Boat handles real good.
    Apr 2017
    so i guess in response to my post, i need a Spotmaster for the Stroker
  16. #12
    Dec 2011
    Ottawa
    Quote Originally Posted by strokerbass View Post
    No not at 80mph, just cone it unless you wanna run that high, my bobs coned 4 hole cle with welded in blowout ring runs way nicer than my sporty on my ally xb03, adding a 3l 250xb this year and just coning my gen 1 TM. I have heard that the gen2 blows out sooner than gen 1, most guys i know get 85-88 on gen1 b4 it gets squirelly
    Mar 2010
    houston, tx
    On a stroker yes, on other boats coned lowers like tq masters and cle’s Etc generally are a little faster but on a stroker run a sporty for best results.
    All boats are different and don’t all like the same things.
    Allys and bullets etc generally like coned 200 cases etc the best but not strokers
  18. #14
    Feb 2011
    Baxter, Mn.
    The Stroker with the 250xs and a sport master is capable of speeds over 100 mph.. Set up for fishing with a prop that will hole shot very well and carry your load at speed you should see mid to upper 90's.. Definitely go for the sport master!
  19. Likes 90 5.0 liked this post
  20. #15
    Mar 2015
    Vancouver, Washington
    I have both, coned unit, and sporty, and I prefer the sporty, I have more confidence in it, and its all aluminum, so no paint or filler to chip. Looks better, and fastest guy I know runs a sporty.
    Whitney Woolard
    Oregon/Washington
    '96 Allison XB2003 w/Mercury 2.5 260ss
  1. 12 or 14 inch bobs machine shop jackplate
    By 2.5-21 in forum Parts Wanted
    Last Post: 10-21-2016, 02:21 PM
  2. bobs Machine Shop nosecone
    By roadkill636 in forum Misc. Parts and Accessories
    Last Post: 06-16-2015, 08:38 AM
  3. Bobs Machine Shop Stabilzer Plate
    By spbutler in forum Props, Setup, and Rigging
    Last Post: 08-29-2009, 09:01 AM
