Results 1 to 1 of 1
Thread: The grid thing
08-19-2017, 09:36 PM #1
The grid thing
Ok the process building!, glassing !,the steel frame ready to be glassed to the mould!, 3 ready made grids and a old mould that has seen better days !
these are for smaller boats but each model had its own grid ! because of hull shape and size and if it was a open boat or a small cabin style family boat with a vee birth and foot well up front !! fuel tanks sat in a proper recess and supported from the grid . simple ,easy to make light weight and worked very effectively and saved lots of time during the assembly and building process !!
Its is also possible to add a element of give and spring by changing the shape of the sides of the stringers on a grid to allow and have a slight spring effect!! add to that a special semi flexible solid glass hull made with the right glass the right way and behold you can have a soft ride production hull !!
Didn't see that one coming did you !!Last edited by tunnels; 08-20-2017 at 02:46 AM.
I dug this old thing up...
By Scream And Fly in forum General Boating DiscussionReplies: 4Last Post: 01-16-2016, 06:34 PM -
What is this thing?
By number21 in forum Technical DiscussionReplies: 5Last Post: 06-24-2013, 03:32 AM -
timing grid
By J.P. in forum Technical DiscussionReplies: 1Last Post: 07-24-2004, 01:45 PM -
the Best thing fer a OMC
By Raptor in forum General Boating DiscussionReplies: 16Last Post: 02-04-2003, 07:42 AM
