Results 1 to 6 of 6
    May 2009
    Ormond Beach, Florida
    To Tilt or not to tilt, that is the question.....
    What's the prevailing opinion on tilting a 300XS all the way up to pull the lower unit out of the water when you are keeping it in overnight (fresh water) assuming the rigging tube and steering hoses are sized to allow it.
    Mark
    May 2001
    Maine
    Interesting question. On my STV Euro with a 225 I generally raise it enough so that in the event it parts from the mooring (which the way I have it made should never happen) and it comes in on the beach it won't damage the prop or lower. I rarely leave it in overnight but when I do at the camp thats my approach. I never go in salt water. I have never had to worry about discoloration of the exposed aluminum on the lower, maybe lakes with a different water chemistry such as high/low pH that could be a problem.
    Sep 2014
    It's direct injected 2 stroke tilt it as high or low as you want. Carbs I would be more hesitant to tilt any more than needed.
    #skaternation
    21 rally sport (sold)
    21 Cougar (sold)
    21 Skater (sold)
    24 skater twin 250 etecs
    Shreveport, La.
    We camp every year and boat stays in water with motor down for week at a time. Never a problem.
    DB
    Apr 2014
    St. Pete, FL
    I leave mine in, even if overnight in salt water which is my boats primary use. I do trim the motors out of the water when I leave the boat docked on the Suwannee just to keep debris from wrapping in the props
    Aaron
    1991 Fountain 31TE, 2005 Mercury 250xs, 26p Bravo 1 FS
    Aug 2002
    Palm Harbor, Fl../ lake tarpon
    Efi or carb dont mater ,,if i dont trim mine out of the water after afew days it will start to get a lil nastry so i tilt up on my
    02 mirage ski racer w/ 2.5
    lake tarpon (LTB racing)
    "Mirage Boats... often imitated but never duplicated"
  1. tilt pin question ???
    By Russ G. in forum Technical Discussion
    Last Post: 04-08-2015, 12:25 PM
  2. Mercury Tech: single ram tilt vs triple ram tilt
    By beamrverbeek in forum Technical Discussion
    Last Post: 10-26-2012, 08:37 AM
  3. Tilt n tilt wiring 1977 johnson 140hp ?
    By phillnjack in forum Technical Discussion
    Last Post: 02-28-2011, 01:47 PM
  4. Found a tilt lock block off plate and SS SOLID tilt pin
    By Skater 32 in forum Technical Discussion
    Last Post: 03-22-2010, 09:12 PM
  5. Three Ram tilt pin question
    By Carter Powell in forum Technical Discussion
    Last Post: 06-13-2005, 12:35 PM
Simon Motorsports
