Results 1 to 10 of 10
    Dec 2008
    san bernardino california
    91 2.4 bridgeport efi
    Are these motors worth rebuilding? I have an opportunity to buy one that runs but low compression. Any recommendations on best person to rebuild it? Its on a 20" offshore mid. Also will the flywheel and ignition system fit on a 2.4 xri 200 efi motor? Would the horn injection work on the xri? Are they the same block? Just Bridgeports make the difference?
    May 2016
    Bean Station Tn.
    If you don't want it let me know where it is I'll take it if it's a good deal ....thanks.... as far as worth rebuilding I think so .... but I don't know as far as what parts will interchange sorry
    Dec 2011
    Ottawa
    ya,I would rebuild it with 6 steel sleeves,and save the cost of nicasil,if you aren't a racer,,it will still turn 7k all day,and give you the horn front,you can put a simon 55amp alternator system on it,,call john marles at US1 he's out there in Cal,and has all the parts and info you need
    Quote Originally Posted by lajons View Post
    Dec 2008
    thanks, he's not that far from me
    Mar 2015
    DFW
    Any of you guys have any idea if 2.4 and 2.5 flywheels are interchangable? I've got a light 2.5L flywheel but will be running a 2.4 now.
    Dec 2011
    Ludington michigan,on the shore
    Quote Originally Posted by Noah Burns View Post
    Yes they will,but you must keep the stator size the same,16amp with a 16 amp flywheel, and 40 with a 40 ect
  7. Thanks Noah Burns thanked for this post
    Likes Noah Burns liked this post
    Pekin, IL
    The Bridgeport and the xri have different front halves so swapping injection will involve swapping fronts. Blocks are not the same. The Bridgeport has a wider exhaust port with a bridge and the xri does not.
    Rock
    Team Junk
  9. Likes Noah Burns liked this post
    Mar 2015
    DFW
    Awesome, thank you for your input, I hadn't considered the matching amp sizes so I'm glad you mentioned that! Thanks again!
    Mar 2010
    houston, tx
    Quote Originally Posted by Varmint View Post
    putting six sleeves in at one time has to be way more expensive than new nic, I understand people doing one or two at a time but if you need that many re nic the sucker IMO.
    Dec 2011
    Six sleeves at the same time,vs new nic is about a wash cost wise.Depends on your wants and needs for the engine.The newer cast Pistons can go 7000+ so a steel sleeve BP could be strong,but care must be taken in the build,or it will surely fail.clearence,clearance,clearence!!
  1. Wtb Bridgeport ecm
    By Cal 47 in forum Parts Wanted
    Last Post: 08-12-2015, 05:21 AM
  2. Mercury Tech: old bridgeport efi?
    By west20.8 in forum Technical Discussion
    Last Post: 08-10-2012, 01:46 AM
  3. Bridgeport 2.4 Help??
    By bigbronc23 in forum General Boating Discussion
    Last Post: 03-30-2009, 05:48 PM
  4. 2.4 to a 2.4 bridgeport or 2.5?
    By 81hydrostream in forum Technical Discussion
    Last Post: 02-07-2004, 09:20 PM
