Results 1 to 5 of 5
08-08-2017, 06:28 PM #17000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Non performance boat performance questions...
So I have my 19' seaswirl up and running. 1989 150 Evinrude xp on the back. Took the carbs off it and made sure they were clean, not a spec of dirt in them. Changed pickup, supply hose and sending unit. Took it out the first time the other night for a test run. 3 adults and 3 small kids, 10 gal of fuel 17 pitch aluminum prop. Ran no prob right up to 5500 rpm and 40+ mph. Swapped to a 19 pitch prop and took it out the next day, seemed ok for a bit, then couldn't get it above 4k rpm. Swapped it out at the sandbar for the 17, had what felt like power loss on the way back. Got home and realized inline fuel filters were clogged with what looked sand type gunk from the tank. Cleaned/replaced them and ran it with the 19 back on it. Still won't go over 4k rpm, can 2 inch of pitch cause that much rpm loss? I thought it was about 200rpm per inch of pitch. the tank has crap in it so the filters are clogged again but I'll figure that out. Unfortunately the 17 pitch prop got chewed up on a shoal. So until I get another the.19 is what I have. Soon I hope to swap to my 3.0 Johnson but for now I wanted this one to run.
08-08-2017, 07:59 PM #2
08-09-2017, 10:22 AM #37000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
compression test it is. I was afraid of that. I forgot to mention that when the filters clogged the second time it was enough to set off the alarm. If I tries to go above about 3k the alarm would sound. Check the primer ball and its soft, pump it up alarm goes off. Tried to run while pumping the ball but the filters wouldn't let enough fuel through to keep up and the ball kept going soft. Any thoughts?
08-09-2017, 10:22 AM #47000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
let me guess, prob #1 piston?
08-15-2017, 07:02 PM #57000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ok, maybe some more help. I did a comp test and all were at 100 psi on all six. none of the spark plugs looked bad and nothing out of the ordinary found. I forgot to mention that both props were 20+ years old so maybe spun hub too. I still need to clean the tank or replace it.
Questions about Performance boat
By smiley88 in forum General Boating DiscussionReplies: 24Last Post: 04-29-2016, 12:28 PM -
By smiley88 in forum Technical DiscussionReplies: 1Last Post: 04-24-2016, 03:05 PM -
Mercury Tech: 2.0 liter merc performance questions
By Richk in forum Technical DiscussionReplies: 4Last Post: 01-12-2010, 10:23 AM -
Questions: OMC J/E 3.0 liter performance
By dominator202 in forum Technical DiscussionReplies: 12Last Post: 04-01-2005, 12:41 PM -
performance questions for the guru's
By bullet19 in forum Technical DiscussionReplies: 1Last Post: 09-07-2003, 03:01 PM
