Results 16 to 30 of 43
    Long Island N.Y.
    On your installation do you run a check valve at the exhaust plate so water pump works fine on idle or you feel it isn’t necessary? Blow off valve around 20lbs?
    Will be installing a pair for my 260s this month, so want to get it right the first time
    Thanks
    Frank
  2. #17
    Jan 2006
    Pompano Beach, FL
    Hull pick up on 308 Skater.
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  3. Likes Frank Molé, Tango, Star1 liked this post
  4. #18
    Illinois
    You must have a check valve if running to the exhaust plate. Otherwise the water pump will direct the water out the pickup tube and not the engine at low speeds or idle. I have used a plumbing check valve from a hardware store.
  5. #19
    Long Island N.Y.
    Do you guys/gals plumb the check valve right into the exhaust plate?
  6. #20
    Jan 2006
    Pompano Beach, FL
    I do not use the exhaust plate. I went to the waterpump. Have no idle issues at all. Works great.
Name:	Lower Unit Pick Up.JPG
    Double
    Rigged
    308 Skater w/400r’s
    Over-Kill
  7. Likes AZMIDLYF, NICE PAIR liked this post
  8. #21
    Mar 2017
    Miami, FL
    If you run it straight to the exhaust plate, the water pump handles idle and low speeds. But what happens on plane when the water pump is spinning with no water because that is the reason you went for a transom pickup in the first place. It does not seem like the water pump will last long. Or does water flow down the water tube into the impeller when on place from the pressure of the pickup?
    Hope that makes sense
  9. #22
    Moline,Ill
    ^yes, there's always enough dribbling down the tube that the impeller stays "lubed"
    is gone
  10. #23
    Sep 2002
    Jax,FL
ID:	434152Click image for larger version.
ID:	434153Click image for larger version.
    Pick-up to strainer, strainer to top of gear case. Strainer has a adjustable pressure relief valve preset @12psi. Everything else ( over 12psi)gets dumped overboard.
  11. Likes Tango, Kcraft liked this post
  12. #24
    Jul 2009
    gatineau qc, canada
    is the strainer only there for filtration or does it serve another purpose?
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
  13. #25
    Filtration and a place to tie the relief valve into the system. I have a few of these if you are wanting to buy pieces, let me know.
  14. Thanks mistah_max thanked for this post
  15. #26
    Dec 2006
    SC
    When you do a transom water pick and you put a noise cone on bo you need to fill in the water pick up holes on the side of the gearcase in?
  16. #27
    could just be the photo, but this pickup looks a hair deep...
  17. #28
    Mar 2011
    Up North
    Teauge marine is best in business
  18. #29
    Jul 2009
    gatineau qc, canada
    ^^ how much is this one^^ . any link of phone number?
  19. #30
    Jul 2009
    gatineau qc, canada
    and do you need to block off the water intakes on the sporty or can you run both without starving the pump? im on the verge of loosing pressure so id like to go higher with the option of comming back down if it dosent work out. id do a more premanent rigging after i know it works better with the remote pickup.
  1. Anyone use a transom mounted water pickup on a pad boat before?
    By neveredge in forum Technical Discussion
    Last Post: 10-31-2013, 05:18 AM
  2. transom mounted water pickup?
    By simplyorange in forum Props, Setup, and Rigging
    Last Post: 08-09-2012, 01:23 PM
  3. Transom mounted water pickup vs. drag of lower unit?
    By Mr. Demeanor in forum Props, Setup, and Rigging
    Last Post: 05-16-2010, 06:19 PM
  4. Transom mounted water pickup
    By cltch in forum Props, Setup, and Rigging
    Last Post: 08-18-2008, 09:19 PM
