Results 1 to 15 of 43
Thread: Transom mounted water pickup
08-08-2017, 01:51 PM #1
08-08-2017, 02:30 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Demeanor did a mod on a bobs for his lil tunnel. It turned out good with a lot of tweaking on his part. Hit the search...
08-08-2017, 03:59 PM #3
Just put one on a 250 Suzuki. Not real pretty but it works.
RockTeam Junk
08-08-2017, 04:08 PM #4
Man, I'd think that thing might slow you down more than going up in propshaft height would speed you up. I'm sure someone will jump in and correct this, but I remember hearing the old pitot tube speedos (which have a much smaller cross section) would cut 3mph off your speed at 100mph, and the faster you went, the more they slowed you down.
Keith-
08-08-2017, 05:01 PM #5Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7148
- 3 Post(s)
Star1 liked this post
08-08-2017, 05:18 PM #6Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7148
- 3 Post(s)
08-11-2017, 08:39 AM #7The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
08-11-2017, 10:42 AM #8
08-11-2017, 11:55 AM #9The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19217
- 3 Post(s)
08-11-2017, 12:22 PM #10
08-11-2017, 12:45 PM #11
James,
Not an STV, but I installed Bob's pick-ups on my Talon 22. The front of the square tube is cut on a 45° angle and a very small length of the tube needs to be below the hull surface to get plenty of water pressure. I recall my first time out I had WAY too much water pressure and just kept inching them up. Maybe 1/16-1/8" of the 45° cut was below the hull when finally dialed in.
In my case I picked up a few mph and the boat handling improved with the engines higher using hull mounted pick-ups.
08-14-2017, 11:30 AM #12
The Bobs unit is junk.
Make your own.
http://www.screamandfly.com/showthre...r-pickup/page5
21' Paramount
Mercury 300 Promax
03-04-2019, 02:00 PM #13
On the STV & LCB installations, did you make a channel in the hull also or does pick up hang a little below bottom of step?
Thanks
03-04-2019, 02:39 PM #145000 RPM
- Sep 2014
- Florida
- 420
- 15
- 25
- 127
If I remember correctly double rigged has some pretty trick water pickups on his boat maybe he will chime in.
#skaternation
21 rally sport (sold)
21 Cougar (sold)
21 Skater (sold)
24 skater (sold)
21 Armstrong (fishing deck) 250 etec
24 SEB (soon to be laid up)
03-04-2019, 05:10 PM #15Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7148
- 3 Post(s)
Anyone use a transom mounted water pickup on a pad boat before?
By neveredge in forum Technical DiscussionReplies: 14Last Post: 10-31-2013, 05:18 AM -
transom mounted water pickup?
By simplyorange in forum Props, Setup, and RiggingReplies: 4Last Post: 08-09-2012, 01:23 PM -
Transom mounted water pickup vs. drag of lower unit?
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 17Last Post: 05-16-2010, 06:19 PM -
By cltch in forum Props, Setup, and RiggingReplies: 13Last Post: 08-18-2008, 09:19 PM
