Results 1 to 5 of 5
Thread: mercury 150xr6
08-08-2017, 09:55 AM #1Junior Member
- Jun 2008
- Greece
- 18
mercury 150xr6
good evening
i have amercury 150 xr6 2003y/o with 150hours
And in my last boat ride after 10 miles stop the engine and all is good after 2 hours try to start the engine and the engine don t start,I opened the left head and the 6 pistons is Has been destroyed.
Do you know why this happened? I did not have any temperature at all.
thank you
08-08-2017, 10:18 AM #2Junior Member
- Jun 2008
- Greece
- 18
08-08-2017, 12:46 PM #3Member
- Jul 2017
- Mn
- 41
- 19
- 7
Looks like one cylinder ran lean
08-08-2017, 02:27 PM #4
Detonation due to lean or timing high on that cylinder. Need to go through fuel system thouroughly and index flywheel for that cylinder and check wot timing on #6. When I had a new set of switchboxes that had a bias problem, #6 was the cylinder it would fry, found it had 5 degrees more timing than #1.
08-09-2017, 04:00 AM #5Junior Member
- Jun 2008
- Greece
- 18
thank you for reply.
2004 Mercury 150xr6
By 99jav in forum Outboard EnginesReplies: 2Last Post: 02-08-2017, 04:15 PM -
mercury 150xr6 wmv carbs and intake
By Cal 47 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 03-31-2015, 01:22 PM -
Mercury Tech: Mercury 150XR6 tuning.
By Atle91 in forum Technical DiscussionReplies: 0Last Post: 09-26-2014, 10:35 PM -
1996 Mercury 150XR6... Good Motor?
By 89Checkmate in forum Technical DiscussionReplies: 2Last Post: 12-28-2010, 08:23 PM -
2003 Mercury 150XR6 heads on 1997 175 Offshore
By mastermarine in forum Technical DiscussionReplies: 2Last Post: 01-17-2006, 10:09 AM
