Results 1 to 4 of 4
Thread: 32 Fountain set up help
08-07-2017, 10:33 PM #1Junior Member
- Apr 2017
- Charleston SC
- 14
05 fountain 32CC running 275s with 700 hours.
Currently motors are in the very top hole "so all the way down" and running 22 pitch bravo 1's
She will run around the 60mph range depending on load. Thinking of moving the motors up two holes and switching to 23s.
If I can't get it up into the low 60s doing that I am leaning towards sending the ECU's to Simons to get flashed. Anyone have or have had a Fountain set up like this with or with out a flash and if so what kind of performance numbers where you seeing?
08-08-2017, 12:27 AM #2
I have an older 31 with 250xs's, I'm seeing low 70's for top end turning 26p bravo one fs. Motors mounted in bottom hole, and top 4 water intake holes plugged. I gained 3 mph from raising the motors, and gained another 3 from changing props.
Aaron
Fountain 38TE, quad 400 Verados
Talon F20 Flats boat, 250XS
08-08-2017, 08:38 AM #3Junior Member
- Apr 2017
- Charleston SC
- 14
Damn 3mph just from raising the motors. Def got to raise these up.
08-08-2017, 05:13 PM #4
My boat topped out 66 with the motors on second hole from top, 68 to 69.9 on the bottom holes, running 25p mirage plus's. Now runs 72.5 with 26p Bravo 1 FS with a little more left in it
Aaron
The new Fountain
By skatermike24 in forum General Boating DiscussionReplies: 11Last Post: 03-18-2013, 11:13 AM -
Donzi, Proline, Baja, Fountain all being moved to Fountain plant.
By Mr. Demeanor in forum General Boating DiscussionReplies: 9Last Post: 12-14-2010, 12:37 PM -
fountain
By joed in forum General Boating DiscussionReplies: 1Last Post: 09-22-2009, 02:26 PM -
Ever seen a fountain like this?
By williamsdetailing in forum General Boating DiscussionReplies: 21Last Post: 06-01-2008, 05:58 PM
