Results 1 to 15 of 17
    Feb 2006
    Brick NJ
    22' Kryptonite 2016 custom venture trailer 2015 Etec 250HO
    2016 Titled 22' Kryptonite just rigged and hit water first time ever last summer
    All Vinyl has been removed but easily can be put back on. Boat 749 On A Mission
    Has brand new Uflex Silverline steering
    Stainless Marine Set Back
    CMC Rapid Jack Jack plate
    Skater Offshore Race seats recovered 2016
    All brand new gauges and red anodized bezels
    Simrad unit
    Custom door down to cabin seals it if you race it
    Boat has extensive custom work to stern and transom area. Bigger stringers added up to fuel tank
    Boxed out entire area with knees Can get pics but lost my phone so I'll have to dig them out.
    All work done at east coast boat restorations in North Caroline and super strong and mint.
    Not one stress crack anywhere. Boat is built like a brick **** house and has raced in 6' ocean and gulf of mexico waters.
    Solid as a rock.
    Full boat cover too.
    2016 Custom Venture Trailer torsion axles and 4 wheel disc brakes with aluminum wheel and steel belted radial upgrades. Have 3 spare tires in case your going on the race circuit.
    Trailer is also MINT
    2015 Etec 250 HO Motor, Priority order/Build from BRP.
    Has less than 100 hours and is perfect. can get anyone a printout if needed
    Runs awesome never let me down.
    Fastest I've seen from boat this far is 68 mph with 50 gallons of fuel and 2 people.
    Have many props to choose from will sell with one or with all.
    Have a class 7 custom Hydromotive.
    Have a BBlades top end
    Have a Bravo 1 I sent down to F&J Props in Ft Lauterdale waiting to get that back hoping it breaks 70/71 w this prop.
    Set up with Hotfoot but have an offshore race control box custom built to work with the Skater Seat and custom aluminum Seat pedestals
    Boat needs nothing. Just considering partnering up with someone and going to a 32' Cat with canopy.
    My loss is your gain.
    36K or best offer for all brand new equipment.
    Spent way more buying boat, motor, trailer, seats, electronics and rigging.
    Thanks Fullers Marine Best in the Business..
    Feb 2006
    Brick NJ
    %5BIMG%5Dhttp://i65.tinypic.com/t0ivio.jpg%5B/IMG%5D
    Sep 2010
    nj
    Saw this out by the 35 Bridge yesterday, really nice boat.
    Feb 2006
    Brick NJ
    Thanks man.
    Quote Originally Posted by 282 View Post
    We put it in by Mantoloking bridge, ran it through canal out into the ocean for a rip by where my friend passed in the race this spring, then went to river rock had lunch, went back through canal to toms river visited some more friends and then ripped home. Still had a half tank of fuel when I got back. Boat runs over 65 w 4 Adults and a full tank of gas in 1-2' chop like nothing.
  5. Likes Frank Molé liked this post
    Feb 2006
    Brick NJ
    To the guy who called about boat today, your message was cut short and I did not get the last two numbers of your cell.
    As far as top speed with Etec Boat went 72 with half tank and the FJ Prop on Delaware river (Fresh water) Should be a hair quicker in the salt water just got too busy to test it before winter set in.
    Sep 2002
    beachwood .NJ
    Real nice boat
    2014 OPA-APBA National Champion Class 7, Hauling Trash 725,
    Jul 2004
    Connecticut
    Thumbs up
    Quote Originally Posted by kbirdmon View Post
    2016 titled 22' Kryptonite just rigged and hit water first time ever last summer
    2015 Etec 250HO motor, priority order/build from BRP. Has less than 100 hours and is perfect. Printout if needed
    2016 Custom Venture Trailer with torsion axles and 4 wheel disc brakes. Aluminum wheels and steel belted radial upgrades
    Full boat cover
    Brand new Uflex Silverline steering
    Stainless Marine Set Back and CMC Rapid Jack jack plate
    All brand new gauges, red anodized bezels and Simrad unit
    Extensive custom work to stern and transom area. Bigger stringers added up to fuel tank. Boxed out entire area with knees.
    Boat needs nothing. 36K or best offer for all. Spent way more buying boat, motor, trailer, seats, electronics and rigging.
    For $36,000 someone is going to get a very unique package
  9. #8
    Nov 2016
    Islip
    Still available? Transom pics? Full bracket or box? What offset setup do you have
  10. #9
    Feb 2006
    Brick NJ
    yes
    Quote Originally Posted by Kismet1985 View Post
    Boat had complete transom on inside reinforced and boxed all glassed beautifully and re gel'd before a hole was ever cut in. Then we hung a Stainless marine 18" Set back on the back. I have ran it with and raced it without a jackplate too. Has hotfoot currently and I also have a center box w controls if you wanted to fly by stick.
    has paddle controls on helm for trim and jackplate.
    Simrad unit for speedo plus a second gps w set up for ipad mini. very accurate speeds. 72/73 two people half tank 1' slop of bay.
    Will go faster I tried a stock bblades obfx prop ran the number I ran now with a worked prop with a bone stocker. With some prop work should run over 75 with a factory stock 250 Will fly with a 300 or a 400
  11. #10
    Feb 2006
    Brick NJ
    https://www.screamandfly.com/showthr...yptonite-boats
    My transom job is in this topic. All custom built transom and stringer reinforcement because we knew we were going to beat the balls off of it.
  12. #11
    Nov 2016
    Islip
    So it's a 20in mid motor with 18' setback. Did you hang stainless marine bracket at 20inch on transom off pad of boat or 25' ?? I would think if you hung it at 25 there would be no need for an extra jack plate. Correct me if I'm wrong. Just very interested in the setup of these boats
  13. #12
    Feb 2006
    Brick NJ
    My bracket Is low. look at the pic. its like a pad extension of sorts I'd say the jackplate was for top end and trailering. if you look most of the rough offshore races we ran we went without the jack plate after point pleasant race because I blew the little delrin or whatever that bushing by the brass was right out. made motor crooked on boat. so when racing offshore we ran without the jack after that it was only for top end
  14. #13
    Feb 2006
    Brick NJ
    For Sale, Want to build a new spec class race boat, cant keep them all. Anyone interested please get in touch. NEW PORTA PRODUCTS BRACKET, NEW WHEELS AND TIRES this year.
    Needs nothing but fuel and oil.
    THanks.
Name:	Englweood Air 2019.jpg
  15. #14
    Feb 2006
    Brick NJ
ID:	477644Click image for larger version.
  16. #15
    Feb 2006
    Brick NJ
    not sure why it posted all those in a row sorry.
  1. STV with a 250ho ETEC
    By stv250 in forum General Boating Discussion
    Last Post: 10-27-2015, 10:23 AM
  2. 250ho etec
    By dzalj1 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-30-2012, 09:54 PM
  3. etec 250ho
    By sleeka$$78 in forum General Boating Discussion
    Last Post: 05-06-2008, 01:14 PM
