Results 1 to 3 of 3
    Jul 2014
    uk
    Modified water intakes/speedo tube?
    Has anyone ever made their own low water pickups on an outboard? Possibly ever modified the speedo intake to supply water to impelller even? Etec l2 gearbox, not sure I want the extran length and drag of a bobs nose cone but need a bit more water
    thanks in advanced
    Aug 2019
    Palmharbor
    Put a crescent bullet on it with epoxy an use the bigger intake screens for high mounting
    Sep 2023
    NY
    Consult a professional mechanic or the manufacturer before modifying the speedo intake or creating your own low water pickup for your outboard motor. Such modifications may cause damage to your motor and should not be taken lightly. It is important to ensure the safe and proper functioning of your outboard motor equipment.
  1. Replies: 2
    Last Post: 02-07-2018, 10:49 PM
  2. Mercury Tech: Mercury 225hp water intakes...
    By tony1204au in forum Technical Discussion
    Last Post: 12-11-2011, 08:57 PM
  3. Water intakes
    By johnny24 in forum Technical Discussion
    Last Post: 07-23-2004, 05:25 AM
  4. Speedo pick up tube placement ?
    By Jerry Millington in forum Technical Discussion
    Last Post: 01-12-2002, 01:14 PM
