Results 1 to 15 of 43
Thread: Phantom 25 Verado 400R set up
07-23-2017, 12:53 PM #15000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
I have approx 50 hours on my new Verado 400R Phantom 25 combo. Top speed is 86 mph at 7,040 rpms with two persons.
The prop I have is a reworked REV4 25 pitch which I bought second hand for my 350 Sci. It was tuned for a Airship RIB 28 footer. Its heavy cupped both close to the hub and on the tip. I have been reccommended to try a stock REV4 25 RXP, since its not cupped so much. I presume I will get this prop soon.
I need to run the propshaft at least 0,75 inches above the bottom with the REV4. No positive trim. Lower propshaft height, the speed drops. Higher, the slip increases. So I am looking for a prop which carry the bow better at high propshaft height.
Have anyone tested the Max5 against props such as REV4, Turbo TXP, BLlades 4-Speed OB/FX, Bravo FS, etc?
Thanks!
Cheeers, Toffen
07-31-2017, 11:59 AM #2
Toffen, I have been running the bblades o/b's for a year now on my twin fountain cc and there great. Call brett he is easy to talk to. He will get you were you need to be. I lifted my motors and the o/b's were the ticket.
Toffen thanked for this post
03-29-2018, 07:54 AM #35000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
May the spring arrive as quick as possible
Cheers Toffen
NICE PAIR liked this post
04-01-2018, 07:59 PM #46000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
In for updates!
04-10-2018, 04:09 AM #55000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
Still snow here, so testing will start primo May. I am also doing some other tweaks to the boat, and really look forward to some hard figures.
Hopefully we can get it to 87,5 mph with 8% slip.
Cheeers, ToffenLast edited by Toffen; 04-13-2018 at 03:36 PM.
tux974 liked this post
04-14-2018, 09:00 AM #6
Nice rig.
Attachment 404775Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
05-13-2018, 08:24 PM #75000 RPM
- Dec 2012
- Detroit
- 212
- 10
Wat were the results, i got same props and my slip dropped from 16% with bravo fs 24 to 14% with max5 24, not happy with my slip
Big and slow
05-13-2018, 08:33 PM #86000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
My slip dropped from 12 to 8% going from a pro max to a max5. At 60 mph cruise, my slip went from 30 to 20% and it went from 3 to 4 mpg.
With bravo1's my slip was off the charts.
05-14-2018, 06:12 PM #95000 RPM
- Dec 2012
- Detroit
- 212
- 10
I have the joy stick cambered skegs on my lowers is this the problem causing my slip numbers to be high ?
Big and slow
05-14-2018, 06:47 PM #106000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
I'm running a cambered skeg as well. Not sure what you mean by joystick cambered.
05-14-2018, 06:54 PM #115000 RPM
- Dec 2012
- Detroit
- 212
- 10
My motors are factory joy stick motors which sm not using joystick but the lowers are cambered
Big and slow
05-14-2018, 06:55 PM #125000 RPM
- Dec 2012
- Detroit
- 212
- 10
Look
Big and slow
05-22-2018, 02:01 PM #135000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi!
I have a cambered skeg as well but different from yours.....
Its not that cambered. Look like you have a torque tab?
Cheeers, ToffenLast edited by Toffen; 05-22-2018 at 02:04 PM.
05-22-2018, 02:06 PM #145000 RPM
- Norway
- 935
- 61
- 13
- 353
- 182
Hi,
Got my boat on the water today
The prop worked well. Managed 86,3 mph out of the box with the propshaft 1 inches above. I have a notch of 8 inches pluss jackplate 4,5 inches. So in real world is approx even with the bottom as the water hits higher with notch and jack.
I will go 0,5 inch higher and see. Slip is very very low. 6,5 % on a non stepped V hull. I need to get the rpms up 150 rpm to get 100% out of the engine, so I will try to raise it. The slip may well go up, but getting it to 7,000 rpms will give me more horsepower.
Cruise speed was good as well. 50,5 mph at 4,000 rpms and 64 mph at 5,000 rpms. With the REV4 25 pitch I managed 48 mph at 4,000 rpms and 61-62 mph at 5,000 rpms.
Hopefully with a little tweak we can it to 87 mph and I am very happy.
Cheeers, ToffenLast edited by Toffen; 05-22-2018 at 02:18 PM.
05-22-2018, 02:31 PM #156000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
You definitely need to go up. The max5 will maintain low slip even really high and getting that big gearcase out of the water is key.
Toffen liked this post
Prop for a Verado 400R & Phantom 25
By Toffen in forum Props, Setup, and RiggingReplies: 0Last Post: 08-09-2016, 09:14 AM -
Article: Verado 400R - Serious Performance Outboard
By Scream And Fly in forum vBCms CommentsReplies: 12Last Post: 03-30-2015, 01:05 PM -
Verado 400R Mercury Racing
By MCRacing in forum General Boating DiscussionReplies: 1Last Post: 02-12-2015, 11:17 PM -
Phantom 25 and its new Verado 350 sci
By Toffen in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 106Last Post: 08-18-2012, 10:43 AM -
Rigging a Verado 350 sci on a Phantom 25
By Toffen in forum Props, Setup, and RiggingReplies: 22Last Post: 09-10-2010, 02:30 PM
