Results 1 to 5 of 5
07-19-2017, 06:34 AM #1
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
mercury v6 upper crankcase bearing cross reference
Does any know cross reference numbers for upper crankshaft bearings with either the 1.375 and 1.500 inner diameters? Timken Skf or what ever?
07-19-2017, 09:04 PM #2
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
What are you trying to do? If you need bearings I have lots.....
07-20-2017, 03:19 AM #3
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
Cheaper alternative then merc prices in Canada
07-20-2017, 12:31 PM #4
Put the merc part number in Amazon search, most of the time it's somewhere around 50% of the merc cost. When I ordered bearings they came from promarineusa.com and where koyo brand.
coffeeguy thanked for this post
12-04-2024, 03:57 AM #5
5000 RPM
- Feb 2015
- South Africa
- 105
- 12
- 7
- 42
Any bearing from any reputable manufacturer has a catalogue number on it. Bearing retailers will supply you adequate substitutes at way less cost than Mercury or Yamaha or or are charging. Timken bought Torrington and is selling them under the Koyo name, which they also acquired to broaden their market share in Japan. The lot is marketed by company JTEKT. Funny enough - they took over the original Torrington numbers.
Hope this helps. Can save you $$$$ on a major rebuild like lower unit.
Wolfgang
Mercury optimax lower unit cross reference
By cyphertech in forum Technical DiscussionReplies: 5Last Post: 08-17-2015, 01:46 PM -
Cross reference - Prop P/n
By Merculator in forum Props, Setup, and RiggingReplies: 0Last Post: 04-14-2014, 06:27 PM -
Cross reference
By GameOns11 in forum General Boating DiscussionReplies: 3Last Post: 08-30-2011, 07:24 AM -
Mercury Tech: mercury ecu part #s cross reference chart
By mercules1750 in forum Technical DiscussionReplies: 6Last Post: 11-03-2010, 08:10 PM -
drag crank upper bearing cross ref
By stoker2001 in forum Technical DiscussionReplies: 5Last Post: 12-07-2003, 08:33 PM
