Results 1 to 9 of 9
Thread: 24 Superboat Prop Question
07-12-2017, 04:59 AM #1
Hey Guys (Girls)
My brother has a newer 24' Superboat (stepped hull) that has a merc 250 on her. Boat runs nice at top speed, but is a real dog planing, and gets worse when passengers are added.
What is the best all around prop for this boat?
How high should engine be?
As always, thanks
Frank
07-12-2017, 11:22 AM #25000 RPM
- Sep 2012
- Florida
- 440
- 15
- 9
- 84
What prop does he have on now?
07-12-2017, 12:00 PM #3
Trophy seem to work well with that hull and motor. I know Superbash liked the 24p on his 300x. Not saying thats the pitch for you but that I believe was his best prop and that hull. JMO
07-12-2017, 04:31 PM #4
Frank, I ran a 25 or 26 Trophy Plus with my stepped bottom with a 300PM. I had an 8" setback with a coned TM.
I can not remember if I tried a ProEt, they also work very well.
Like Vnemous said it will depend on your setup and engine height.
07-17-2017, 04:50 PM #5
Setup when he purchased
Prop is a mercury revolution 4 blade 23p with 4 holes
6" setback
Point of lower unit is 5" below
Boat runs nice at WOT, but run more than two people she has a hard time planing (couldn't pull a drunk out of bed). Motor can't revup
Thoughts??
Thanks
07-17-2017, 04:52 PM #6
Pretty deep especially if your transom is notched.JMO
07-18-2017, 07:04 PM #75000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
A 23" Rev4 was great on my 21' Checkmate. I had another set of 4 PVS holes added. Only then would it rev up good for hole shot.
5" below the pad seems way too low. The Rev4 has a ton for grip and can be run really high.
07-18-2017, 08:36 PM #8
I run a 27 bravo xs on my step bottom 24 with 300xs, propshaft level with bottom torque master lower and it jumps out of the hole, I've found that the 24 like the bigger diameter props, couldn't get the trophy to hook up well
07-22-2017, 06:28 PM #9
I READ solas scorpion run very well on your kinda rig. there 15.25 dia great lift hi-rake but underrated with pitch # a 24 is like turning a merc 26
what prop do i use no 24 superboat
By rob_lup in forum Props, Setup, and RiggingReplies: 3Last Post: 09-06-2011, 05:46 AM -
What prop for a 24 Superboat
By zachp13 in forum Props, Setup, and RiggingReplies: 2Last Post: 11-10-2007, 01:26 PM -
21' Superboat prop?
By quicktrip in forum Props, Setup, and RiggingReplies: 20Last Post: 08-18-2007, 09:10 AM -
21' superboat prop question
By screamindemon in forum Props, Setup, and RiggingReplies: 16Last Post: 07-12-2006, 09:46 AM -
Prop for 21 Superboat???????
By screamindemon in forum Technical DiscussionReplies: 0Last Post: 07-11-2003, 11:52 PM
