Results 1 to 5 of 5
07-11-2017, 12:42 AM #1Member
- Nov 2012
- Tillsonburg
- 89
Using top guided rods with bottom guided mahle 260 pistons, how to stack washers
I have a set of bottom guided mahle 260 pistons and i am trying to stack the thin top guided washers to make the top guided rod work. I need to stack 4 washers on one side and 3 on the other to make the rod fit into the piston. This leaves the rod off center, is this a problem? I know people have done this before so any info would be great. I know there are thick washers available from pro marine and mercury for this application but would rather take this route if possible.
07-11-2017, 05:48 AM #2
Needs to be equal.Try a parts wanted ad, in the buy and sell.
07-11-2017, 06:43 AM #3
I use Mahle pistons with 818141 rods. I use one thin and one thick OEM Merc washer on each side. Has worked perfect for 20 years
death is certain; life is not
07-11-2017, 07:49 AM #4Member
- Nov 2012
- Tillsonburg
- 89
07-11-2017, 11:35 AM #5
Pro Marine part # WP37WW
IT AIN'T FAST , IF ITS NOT ALLISOON MAN POWER!!!
Top guided rods in bottom guided pistons.
By MALCOLM MCGEHEE in forum Technical DiscussionReplies: 3Last Post: 06-24-2010, 12:56 PM -
Top Guided vs Bottom Guided Rods
By Murry in forum Technical DiscussionReplies: 2Last Post: 10-11-2009, 07:56 AM
