Results 16 to 30 of 33
07-12-2017, 06:56 AM #16
yeah its call "COMMON SENSE "is the best one I know of !!!
GLASS fibres bent at a dead sharp right angle shear and break very easily ! But with a continuous cove the whole length both sides things change dramatically , A 15 mm radius is ideal is easy to laminate glass into and around !! this is a place where double bias is best NOT 0/90 and stops the glass from breaking and disintegrating shear still take place but still holds much much better .
What you use for coving with as also important !! doesn't want to be brittle or crumbly so will break and crack ,so needs micro fibres in the mix !!
THESE THINGS ARE ALL TO DO WITH BUILDING METHODS !! this subject alone there volumes of things that you can do !!!Last edited by tunnels; 07-12-2017 at 05:15 PM.
powerabout liked this post
07-13-2017, 11:29 PM #17
07-13-2017, 11:41 PM #18Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-14-2017, 12:19 AM #19
Way back we always made our own fillers and coving compounds from Standard resins and a flexi resin plus all the other dry stuff !! It was great ! easy to work with had the consistency of stiff whipped cream and being semi flexible stuck really well to most anything and All the resins stuck to it as well ,I used to take some home for car repair etc that was before the days of bondo etc !
Any thing made for boats has to have flex and stick ability or you are asking for trouble !! everything must be able to move even fractionally with vibrations from a thumping diesel engine that travels the whole length of some boats for days on end if its a fishing boat and the likes !
For bulkheads in yachts and all the internals that got stuck in and were also used for hull stiffening and structural was used in lots of places before it got glassed over !! A high percentage of the yachts we were making used to get used for extended off shore cruising to the pacific island and Australia and points north even to England and the med all from New Zealand and down the southern isolated islands towards Antarctica into freezing cold places and ice packs etc !. like I mentioned off shore building specs were more stringent than survey specs !!
These days if it doesn't come in a tube or you cant buy in some shop no one has a clue how to make things themselves any more !
The pioneering spirit and common sense know how doesn't exist any more !! we had formula's scribbled on the factory walls for all the mixes and stuff we had to make for different jobs !! Failures were unheard of !!.
Trouble these days is there is such a vast selection of things that COULD BE USED but there's the compatibility issue to contend with , It will stick YES BUT what will stick to it ??
Things like osmosis was never heard of and never appeared until they started Spraying gel coats because all and everything was hand brushed and the brushing squashed the air and gas bubbles out and porosity didn't exist ! remember you saying something about osmosis some time back Plus workmanship was another thing all guys I worked with were Boaties and boating people so they took great pride in all and everything they did didn't mater what it was !!
On sunny warm days with any sort of a breeze 50% of the staff never came to work including the boss because they were up and out at the crack of dawn out on the harbour sailing all day any where didn't matter as long as it was sailing !! no cell phones just peace and quiet !!!
Sport of sailing means everything to some guys and the boss we had was one such person no body got told off for not coming to work when they were out sailing it was just a glorious day and that mattered more then working ! the work still gets done just takes longer !!.
This is something that really stands out in the Americas cup interviews with the team members of team New Zealand is the family atmosphere and the just being there nothing else matters ! The team has spent the last 2 weeks going to all cities in all of nz to share there trophy and give thanks to all and everyone old and young !!Myself as a kiwi but living in China I to feel proud to be a kiwi even though I had no one here to share the enjoyment with !!Last edited by tunnels; 07-16-2017 at 06:07 PM.
07-19-2017, 02:46 AM #20
01-16-2018, 03:22 PM #21Junior Member
- Jan 2018
- Laramie, WY
- 15
- 21
- 7
Back to the original subject. It has been many years since I have done any 'glass work and now that Project HSB is being delivered in Feb I have been researching things. I have watched several videos on this voodoo magic cloth called Peel-Ply. Wow what a work-reducing product eliminating most grinding and sanding. I do not know how it works, nor do I care at this point either....we will use it and love it and call it magic
Pyro
01-16-2018, 04:34 PM #22Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It is nice to use if you have time while hand laminating to lay it out and roll over it. Keeps the fresh glass clean till you peel it.
Pyro Chuck liked this post
01-16-2018, 04:50 PM #23
On my Vking I would leave the pealply on the core until I was ready to do the next section, pull it off and the glass is ready to be laminated over again. It is a must in bagging, but a real time saver in hand lamination with epoxy.
1973 Viper - sold
1978 Viking - sold
1995 XB02
01-20-2018, 02:43 PM #24
My current project was my first time to use it.
I did hand laminating, and the only issue I had was after rolling over it, if I left any excess resin, it was a bit hard to get it to release. I'm sure I did something wrong there, but it did release with some effort, and did leave a great surface for the next layer. When I squeegeed any excess resin away, problem solved.James H. W2F a V-King... Want 2 Fly a V-King
01-21-2018, 08:28 PM #255000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
I just used it for the first time. Can't believe it took me this long to use it. It'll save me so much time. Mine peeled off fairly easy
1BadAction, Pyro Chuck liked this post
02-05-2018, 08:23 PM #265000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
We use it on the composite rotor skins and other experimental parts we make at work. Only issue I've noticed is in tighter radii it seems to leave a slightly rougher finish (even when bagged) and can be harder to remove without causing damage in those areas. I do not personally do any of the lay up or removal, just speaking from close observation. It seems like removal in 45* angles from the direction of the run work best to avoid de-laminating issues that we have had in the past.
STV Pro Comp Ski| 200 Merc
04-06-2018, 04:34 PM #27
two dissimilar materials in the mold build, peel ply is used to begin the foundation for the hard putty that will be applied on the female mold tooling
after the resin has dried, the peel ply is removed giving a nice strong consistent thickness base for the hard putty (which will be applied next).
Then milling of the putty continues with finer and finer (drill) bits
Note: the white cube is foam.
04-07-2018, 06:05 PM #28The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
Looks like "vail" material.
04-10-2018, 05:15 AM #29
Fujimo, can you explain what vails are used for?
04-10-2018, 07:04 AM #30Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
He might mean tissue cloth to prevent print through?
noli liked this post
Peel ply!!
By tunnels in forum Fiberglass and Composites DiscussionReplies: 19Last Post: 09-28-2016, 03:07 AM -
Everything you ever wanted to know about peel-ply - and much more...
By Dougw in forum Fiberglass and Composites DiscussionReplies: 20Last Post: 01-03-2011, 08:20 AM -
How to 'peel' an egg without peeling!
By ress453 in forum The Scream And Fly LoungeReplies: 3Last Post: 08-06-2008, 10:46 PM -
how to take off orange peel??
By bluecheckmate in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 06-06-2006, 12:17 AM -
To peel or NOT peel horsepower decals??
By Ron V in forum General Boating DiscussionReplies: 2Last Post: 01-29-2005, 08:13 PM
