Results 1 to 7 of 7
07-09-2017, 09:45 AM #15000 RPM
- May 2005
- Louisiana
- 196
Mercury Verados 300 2nd generation lift pump woes ?
Can anyone tell me if Mercury has redesigned the FSM on 2nd generation Verados ?
We keep getting, I think air in the canisters in rough water conditions .. tanks are clean, filters are new and fuel system ( lines ) are tight to the engines .. I am starting to think the plastic quick disconnects are the culprit ... thanks in advance
07-09-2017, 09:53 AM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Can't say I've seen that problem. What I have seen is the float switch in the FSM get ,hung/stuck/go bad or otherwise not send the signal to turn on the lift pump. You need to get CDS hooked up and make sure it's working right
Also they did update the program from the early motors to look for less fuel mass used before the pump comes on. An ECM flash to a updated version should keep more fuel in the module.
07-09-2017, 10:12 AM #35000 RPM
- May 2005
- Louisiana
- 196
Has anyone redesigned a better fuel delivery system than the OEM FSM ?
I don't like the idea of this system ... would rather the old Bosch type external fuel pump and an internal hull low pressure delivery pump system ?
07-09-2017, 10:14 AM #45000 RPM
- May 2005
- Louisiana
- 196
RSWORDS do u know the firmware update number to look for ?
07-09-2017, 10:46 AM #55000 RPM
- May 2005
- Louisiana
- 196
07-09-2017, 11:22 AM #66000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
07-09-2017, 11:23 AM #76000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
Mercury 300 Verados 2nd generation lift pump woes ??
By davepnola in forum Technical DiscussionReplies: 1Last Post: 07-11-2017, 09:18 PM -
2011 Mercury 350 Verados,
By caldwellrace in forum Outboard EnginesReplies: 2Last Post: 02-05-2017, 12:12 PM -
Mercury Verados For Sale
By DrCatcher in forum Outboard EnginesReplies: 0Last Post: 06-16-2016, 01:30 PM -
Mercury fuel pump lift power?
By s10gto in forum Technical DiscussionReplies: 3Last Post: 06-19-2015, 06:09 PM -
Trim Pump woes
By ShorePounder in forum Technical DiscussionReplies: 14Last Post: 09-11-2003, 07:24 AM
