Page 3 of 3 FirstFirst 1 2 3
Results 31 to 34 of 34
Thread: omc jet sizes
  1. #31
    8 Post(s)
    Quote Originally Posted by 87vantage View Post
    Well a little update on my 3 Cylinder.....I figured out that the jets should be bigger for the carbs Im using , So I went from 50's and 32's to 52s and 34's, and the motor performed perfectly ......But after riding it around at 4000 RPM for a while I went up to 5000 Rpm and is wanted to run hot....The pee tube has a full stream but it definitely ran hot. This is the year model that required the cooling updates, which I have done. I moved the pee tube to the top of the block and replaced the thermostat and bypass spring that the update from OMC specified. Im thinking the thermostat didn't open or I have a blockage is the water passage ? Will it cool properly if I remove the thermostat and leave the bypass and spring in it?
    How did you determine to ran hot?
  2. #32
    May 2002
    L.A. (Lower Alabama)
    I have a digital gauge with the sender screwed into the threaded boss in the top of the head, i watched the temp climb to 190 and as I slowed down it actually stuck....I never tried too restart it. Just got it back on the trailer, checked the compression , they are all still at 120 and I removed the head to inspect everything and it was all good...
    1987 Vantage XT 200 Pro Max
    1991 25 Liberator 300 xs's
    1967-8-9 Z28 Camaro
    1968 SS/RS Camaro Convertible
    1969 SS 396 L89 Camaro
    1970 440 6 pac GTX
    14' jon boat 15 John-rude!
  3. #33
    you need to either update exhaust cover or take out the rib in your old one..
    yes it does make a big difference.
    notice on the newer exhuast cover pate there is NO rib where i point the red line to..
    simply grind that out and its then the same as the newer updated one..
    Attached Thumbnails Attached Thumbnails 29354481_10215047670561135_5017073635417117975_o.jpg
  4. Thanks Captain75 thanked for this post
    Likes Forkin' Crazy liked this post
  5. #34
    Apr 2023
    Birmingham
    Does anyone know what angle the taper is cut through the jets at? Ex. 4° off centerline.
  1. Mercury Tech: Regarding Jet Sizes.
    By MidnightCarving in forum Technical Discussion
    Last Post: 05-26-2010, 07:06 PM
  2. Mercury Tech: jet sizes
    By dadgumit in forum Technical Discussion
    Last Post: 06-30-2009, 10:45 PM
  3. Jet sizes (help please)
    By Vectorized in forum Technical Discussion
    Last Post: 04-25-2008, 06:50 AM
  4. WH-20 jet sizes
    By dynobo in forum Technical Discussion
    Last Post: 01-02-2006, 08:57 AM
  5. Why different jet sizes on 2.4?
    By Mach2 in forum Technical Discussion
    Last Post: 03-26-2004, 01:13 AM
