Results 1 to 5 of 5
07-01-2017, 10:28 PM #15000 RPM
- Sep 2012
- Las Vegas
- 163
- 12
- 10
- 20
- 15
How to best convert 2004 250XS 25" to 20"? I also have 1994 225 3.0 Carb 20" shaft.
Ok, my goal is to convert my yet unmounted 25 inch 2004 250XS into a 20". What's the best most economical way of going about this?
I also have a 1994 20" 3.0 225hp carb Merc, which I would prefer to leave as a 20", but if I cannot find someone who wants to
swap their 20" Optimax lower and mid for my 25", then I might consider swapping the parts out between each other, if that is even possible.
What's the best way to to go about this? What would you guys do?
Anyone have a 20" setup they would like to swap?
Outboards are not that common in my area, so it's extremely rare to see any parts or used up come up for sale around here.
Thanks for your input.
07-02-2017, 12:31 PM #2
If you wanted to you could take your opti powerhead and exhaust adapter and put it on the 20" you have. I infact am doing one in the shop tomorrow.
07-03-2017, 04:04 PM #35000 RPM
- Sep 2012
- Las Vegas
- 163
- 12
- 10
- 20
- 15
Good to know. I'm assuming that includes swapping the pan and cowl to the 20" mid?
Does this mean I can also swap my 94 3.0 powerhead, pan, and cowl onto the Opti 25" mid?
Thanks
07-04-2017, 08:11 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The 1994 exhaust housing is a little different than the newer opti. The tuna is short and boxy on the opti. The old 225 has a long narrow tuna.The newer one is better. The old style upper plate tends to crack when over heated, and has less cooling passage. You can't put the newer style tuna in the old exhaust can because the driveshaft Hole is not the same shape. You could hit that with a grinder for clearance. Good luck.
07-04-2017, 09:30 PM #55000 RPM
- Sep 2012
- Las Vegas
- 163
- 12
- 10
- 20
- 15
Dave, thank you for the details on this. Sounds like I should leave the 94 3.0 as a 20, and try to find someone with a 20in Opti to swap parts with. Or else sell the whole 250SX and look for a 20.
I suppose I could use a jack plate (I already have a hydraulic one on my 20" transom but don't think it goes up another 5") but I would rather not.
Convert Mirage Jaguar Ski Racer 20" to 15" Jackplate question
By stv1991 in forum Props, Setup, and RiggingReplies: 0Last Post: 01-17-2016, 08:28 AM -
MINT "ALLISON CUT" CHOPPER 28" Small shaft MERC
By Valero2.5 in forum PropellersReplies: 0Last Post: 10-18-2015, 10:47 AM -
Mercury Torque Master Gen 2 Gearcase "WingMaster" 3.0 1.75/1 20" shaft Lower Unit
By dreamerdfl in forum Lower UnitsReplies: 2Last Post: 01-19-2015, 12:31 PM -
Can a 5" lower unit spacer be used to convert a 20" to a 25" on a 300 Promax?
By mragu in forum Technical DiscussionReplies: 7Last Post: 03-31-2014, 08:13 PM -
"Sum Ting Wong," "Wi Tu Lo," "Ho Lee Fuk" and "Bang Ding Ow"
By STVmod in forum The Scream And Fly LoungeReplies: 9Last Post: 07-15-2013, 09:34 PM
