Results 1 to 10 of 10
07-01-2017, 04:25 PM #1Member
- May 2017
- baton rouge
- 45
96 mariner 225 2.5 water pump part number
I cannot read the serial number on my motor . Can someone please give me the part number so I can order one ? Thank you
07-01-2017, 08:36 PM #2
ebay alpha one 47-89984T4 11.00 $ use them in all my 2.5 and 2.4
07-01-2017, 11:05 PM #3
That number is the best impeller the brass one not the paper one they sell in the kits. If ya need a kit with gaskets and upper plastic housing this is the part number for that. 46-96148T 8. The kit comes with an impeller but get the one Eli said to get the one in the kit is paper and wont last or be as good as the Brass bushing 89984T 4..
ALSO!!!! when ya take out the impeller get a screw driver and slowly pry up the bottom plastic housing under the metel plate and gaskets. Theres a Gasket under there that can also tear!! I checked mine last week and it was torn. There is a gasket for that in the kit i provided the number for. There is an O ring you will see that ya pop out to take off and put on the new gasket. Easy peezy but most dont bother checking that one!! there is also a new O ring in the kit. every time you buy the kit save the stuff ya dont use like the little yellow gaskets there for when ya change the gear lube for the drain and vent plugs.
And BTW almost every and any merc dealer will have these part numbers in stock. They are used on so many merc motors. You shouldn't have to order them. Well i did say most even my little hole in the wall dealer has them. hahaLast edited by whipper; 07-02-2017 at 12:00 AM.
pkstv liked this post
07-02-2017, 07:44 PM #4Member
- Sep 2013
- Knoxville, TN
- 68
- 16
- 24
How do you tell if it is genuine MERC on Ebay? Too many show up on the search but in the fine print it is some other maker.
whipper liked this post
07-02-2017, 07:51 PM #5
You also need to know 1/2" or 3/4" tube, as far as I know, no complete kit exist for the 3/4" tube
is gone
07-03-2017, 02:52 AM #6
It will say on the package. http://www.ebay.ca/itm/Mercury-Water...9YCPxm&vxp=mtr Also verify what Buzzin said about the water tube. Thats easy to tell. if you gearcase is off just measure across the tube. :]
07-03-2017, 02:54 AM #7
This one is the best impeller. http://www.ebay.com.au/itm/QUICKSILV...-/370554296624
07-03-2017, 03:04 AM #8
These two parts work for 1/2 inch water tube assy. If your not sure take off the gear case motor up in neutral. You can lay it on the ground a towl dont but it on the ground without a blanket or towel down you'll scratch it. Best thing to have is a couple of 2x4 or 2x6 screwed to the end of a bench. And rest the case in between them like a cradle.
07-05-2017, 11:02 PM #9Member
- May 2017
- baton rouge
- 45
Thanks for all the info guys . I have an xr6 gearbox is that makes a difference .
07-06-2017, 02:04 AM #10
Nice fast case no these part numbers are the same for XR6 mine is a 200 case same impeller and housing for 1/2 inch tube TM ect... Just went threw all this going from my 200 to the TM.
3.0 225 mercury 2001 water pump part number
By zbgy1 in forum Technical DiscussionReplies: 4Last Post: 05-24-2013, 07:57 AM -
Fuel Pump Bracket Part Number
By STV_Keith in forum Technical DiscussionReplies: 2Last Post: 01-14-2004, 10:58 AM -
FUEL PUMP - Bosch part number?
By Graham in forum Technical DiscussionReplies: 4Last Post: 02-17-2003, 01:48 AM
