Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
    Ontario, Canada
    Quote Originally Posted by Torben E View Post
    I own a small cat that has a big hop / hump zone and would like to ask if there is somthing
    i can do to reduce that. The hop starts as early as 50 mph and stops around 80...
    Hi Torben - your porpoising experience is pretty common for tunnel boats. Porpoising is more prominent with hull designs that have lower Deadrise (sponsons) OR higher Trim Angles. Often tunnel hulls have BOTH, and so they can often see the onset of porpoising more easily than other hull types. A boat that is susceptible to porpoising will start the process when it's triggered by a change in dynamic balance, such as entering the "Hump Zone". Tunnel hulls also have quite a pronounced Hump Transition, so this can be a significant trigger for the onset of Porpoising.
    There are some things (other than design optimization) that can be done to change the velocities of the Hump Transition and to minimize the drama of porpoising. Some of these have been suggested in your thread above.
    You can also have a look at this Porpoising Article here.
  2. Thanks Torben E thanked for this post
    Likes Torben E liked this post
  3. #17
    Jun 2014
    Denmark
    Thanks for the answers. They are very appriciated
    There are some things i need to try. And some reading to do.
    This is a great forum for fast boats, im sure the best on the net
  1. 24 small ear chopper worked small shaft
    By hydroguy85 in forum Propellers
    Last Post: 09-08-2015, 05:52 PM
  2. Anyone need a small prop for their small boat??
    By 200XSAlli29 in forum Propellers
    Last Post: 06-24-2014, 12:59 PM
  3. Replies: 2
    Last Post: 03-18-2014, 07:13 PM
