Results 1 to 8 of 8
    Jun 2017
    fife scotland
    Anyone pad dimensions for a Sidewinder Super 16 ?
    Looking to fit a pad to Dateline Bikini ( Sidewinder copy )
    I have searched every where and can't find the info i need.
    My boat is 15ft and is almost identical to the super 16
    I have a couple of pics of a winder with a pad but thats as close as i could get.
    Don't know any dimension Click image for larger version.
ID:	378907Click image for larger version.
    Attached Thumbnails Attached Thumbnails 20160626_120011.jpg   sidewinder pad 1.JPG
    The great corn desert of Iowa
    The 16SS had a round bottom. The only Sidewinder with a pad was the 14SS and it is just a delta pad and is 7" across at the back.
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Quote Originally Posted by spybot View Post
    Making a pad First you need to say what are your expectations and hope it will do ,
    what and how the boat will be used ?? !
    do you expect it to be a go fast ??
    or just a good everyday kind of ski boat??
    and how many people do you carry most of the time ??
    in all reality have you thought about trim tabs ??
    That photo is a step wouldn't have dome much if !anything
    Jun 2017
    fife scotland
    The boat hopefully will be a fast lake boat running a 115 hp johnson
    She has terrible chine walk around 40mph
    Carry 2 Have trim tabs on her just now.
    Jul 2007
    Chine walking AT 40 MPH ?? could be even worst with a pad !! what is the top speed !!
    Playing with a pad sure as hell isn't going to fix it from chine walking !! ,
    sounds like the motor wants the whole set up looking into and also !!,
    so how you trim your motor ??
    never forgetting balance of the whole boat !!
    Need lots photos please of the motor and the set up to look at heights and trim etc etc !!
    Jun 2017
    fife scotland
    Hi Tunnels
    Top speed is around 42 (thats with her with a 85 V4 ohnson)if i can keep the chine walk under control.
    I will take lots of photos at the weekend. I would really appreciate any help on setting the boat up.
    Jun 2002
    Lake Norman NC
    Chine walk can be a symptom of loose steering. Try this: Either lock down the steering wheel or have some one hold it firmly then you go to the stern and try forcing the engine side to side. See how much movement you can induce. Even a couple of degrees can create a harmonic back-and-forth movement as torque loads and unloads the steering. You may not notice it while driving as you are fighting the chine walking on plane. Even loose or worn motor mounts on some engine designs can create enough of a shudder or vibration at speed that chine walking may develop. It may not be the whole problem on your boat but it is certainly something to work to reduce or eliminate as a contributory cause.
    1972 Raysoncraft 18LP v-drive Chev 454
    1975 Raysoncraft 17' outboard 200Merc 2.4
    1989 Celebrity 199 I/O 350 Chev ZZ3/Alpha
    2001 Baja Outlaw 25- 496HO/Bravo
  8. Likes XstreamVking liked this post
  9. #8
    Jun 2017
    fife scotland
    Quote Originally Posted by Raysoncrafter View Post
    Thanks for that Ray i will check that his weekend. Never thought of googling causes of chine walking. That is a really good point. Thank You Sir
  1. non bia dimensions?
    By keeper in forum Props, Setup, and Rigging
    Last Post: 08-23-2008, 05:50 PM
  2. Replies: 0
    Last Post: 05-08-2006, 08:15 AM
  3. 1971 16 ft Super Sidewinder
    By Tom Foley in forum General Boating Discussion
    Last Post: 06-19-2005, 05:16 PM
