Results 8,176 to 8,190 of 12497
01-26-2021, 10:44 AM #81766000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
Gearcase Paint Specs
Yeah..............I tried starting a thread about gearcase paint specs on S&F but nobody responded? Pretty straightforward on modified classes but the arguments and yelling always centered around the "stock / OEM" classes. Nobody wanted to clarify the rules about wet sanding paint either? There were even arguments over the surface finish specs on bare aluminum? Merc used primer and Phantom Black on their first SSM inlines but the paint disappeared when the CLE cases first appeared. I can't recall ever seeing any paint used on either Merc or OMC CLE style cases? If they did, can somebody can prove me wrong with a photo?
01-26-2021, 10:54 AM #8177
Well..UIM made it clear.
You did not have to spray paint the gear case as long as the gear case meet the specifications you where legal.
A note is..no paint did not increase speed.
01-26-2021, 11:03 AM #81787000 RPM
- Dec 2002
- South Florida
- 2,296
- 155
- 542
- 11 Post(s)
In APBA gear cases had to be painted as it left the factory.
01-26-2021, 11:16 AM #8179
Well..but we raced under UIM.
A spare part gear case came from OMC without paint.
The spray paint in a can from OMC (Johnson or Evinrude) did never stick perfect.
Paint came lose and looked terrible..
That was the reason for no paint.
Used up a lot of gear cases 1975 because the bearing holder cracked.
01-26-2021, 11:59 AM #81805000 RPM
- Dec 2005
- Keswick, Ontario
- 593
- 101
- 111
- 449
- 282
- 8 Post(s)
01-26-2021, 12:13 PM #8181
powerabout liked this post
01-26-2021, 12:23 PM #8182
European Champion for the third consecutive year 1975
After the Race in Forsaa, Finland and my enormous success in the SE class the
past 3 years winning over 50 races rumors was circulating that I had a special engine from OMC.
Well, I DID NOT and the engine I used on my own Clerici SE boat 1975 was a stock short leg 75 Hp Evinrude from my inventory at my dealership.
A legal higher compression cylinder head was the only change, and the race power trim and stiff rubber mount.
I can tell the truth now, and the speed advantage was from the boat and the set up and my driving style.
One way to get the much higher top speed was to raise the engine up much higher than normal race set up.
The stock gear case was like a brake, and I was 2-3″ above everybody else, BUT that made it very difficult to drive/handle the boat.
The prop lost the grip, and the engine lost the cooling water but the trick was to just before the prop lost the grip to use power trim and throttle/steering to avoid that to happen.
I tested for many days and weeks how far you could drive before the engine started to
overheat and that was around 900 meters.
I lost many powerheads before I found out a way to back of just a little to pick up enough water to cool the engine on the straight a way before the turn.
On top of that you have to use the power trim in and out in a special way to make the “air bag” under the tunnel to lift the boat and I have to say that was my best
advantage.
The Big race this year was Sabaudia Italy, and I called friends in Italy to find out about this new place for the race and was told that it is in a Lagoon, shallow water and flat water.
That was for me great news, and I worked on raising the engine even higher on the transom and picked up a few more MPH.
There was a local race in Stockholm before the Big one, and I used that race as a test. Bad news..hooked and rolled.
Damage the boat, a few days after I told Paul Kalb that I preferred
to race my own boat instead of the factory SE boat.
I got help to repair my boat just in time to make it to Italy.
Normally I was hiding everything I was doing, (learned from Molinari) but for this Big race I changed that.
Parked the boat in the pit so everybody could see my set up and prop.
I told the Race officials that I want my engine inspected before the
race to put an end to “the special engine”rumor.
They said No, but told me that my engine is going to be inspected very seriously after the race if I was the winner.
I have never felt so ready to win a race and now all the good things started to happen.
Around 35 boats was at the race, and most drivers looked at my race set up and started to raise up there engines higher. That was my plan…
Mercury had maybe 10 drivers using the 650 XS.
4 heat, 3 counts and clock start and I was pretty good at them and took the start and turned first.
Then just pulled away on the long two turn race course.
Many drivers was hooking left and right, because they could not
drive with the engine that high.
This race was for me a perfect one. I won 3 heat in a row and did not race the last one.
I asked the officials to start taking my engine apart and they did.
The power head, mid section even the gear case to check gears and impeller and everybody could now see it was a stock 75 hp Evinrude.
Never worked on the ports or pistons.
Just standard.
Lots of disappointed people when my engine was cleared, but
Lars was happy and the European Champion for the third consecutive year.
01-26-2021, 12:48 PM #8183
01-26-2021, 01:01 PM #81846000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
01-26-2021, 01:03 PM #8185
I think we can leave Merc gear-cases questions-problems for all the other Merc threads at S&F.
Thank you.
@2us70Last edited by lars strom; 01-27-2021 at 12:39 PM.
01-26-2021, 01:04 PM #8186
Capt.Insane-o liked this post
01-26-2021, 01:21 PM #81876000 RPM
- Nov 2006
- 1,497
- 13
- 130
- 70
- 627
- 35 Post(s)
01-26-2021, 01:57 PM #8188
01-26-2021, 05:22 PM #8189
lars strom, Instigator liked this post
01-26-2021, 06:44 PM #8190
Evinrude & Johnson Racing 1967+
By Mark75H in forum Outboard and Racing HistoryReplies: 46Last Post: 04-24-2023, 09:58 PM -
V8 Johnson/evinrude Outboards
By baassoc in forum General Boating DiscussionReplies: 23Last Post: 04-17-2020, 06:21 AM -
D and E Class OMC outboards, Johnson 60 and Evinrude 75
By smokin'joe in forum Outboard EnginesReplies: 0Last Post: 05-21-2017, 09:24 AM -
I made a video showing the tear down of a Johnson Evinrude 1975 nitro gear case
By regrp in forum Technical DiscussionReplies: 0Last Post: 10-02-2014, 09:07 PM
