Results 1 to 5 of 5
06-06-2017, 01:19 PM #15000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Hydraulic pump rebuild land and sea
Has anyone rebuilt the hydraulic pump on a land and sea jack plate where the ram pump and motor are all one unit. I took mine apart since it is not working well the fluid had emulsified water but the seals all looked good none of the springs or check valves seemed to be stuck. The two plastic gears appeaed to be in good shape. The only two things I could think that could be wrong is the plastic gears dont have tight enough tolorance anymore or the little steel ball check valves are not sealing properly. Any help would be appreciated. Do you think a hydraulic repair shop would be able to rebuild it?
06-06-2017, 08:16 PM #2Member
- Jun 2014
- Rice Lake, WI
- 43
- 9
- 25
06-06-2017, 08:24 PM #35000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Did any of them have any ideas why they didnt work?
07-02-2017, 02:39 PM #45000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
07-06-2017, 08:15 AM #5
That is exactly what I've done to mine as well and it runs great. It's a good jack plate except for the plastic sleeves, you have to be very carefull with them they destroy easily
Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
