Results 1 to 1 of 1
05-24-2017, 09:38 PM #15000 RPM
- May 2005
- Louisiana
- 196
300 Verado overload in fuel hydrolock # 6
Please help thanks : 300 Verado 2007 .. # 6 cylinder hydro locked with fuel
Ok we are going out ... And barely hit a tree stump on the port motor ....
Engine then dies .... After checking fuel pressure ... We only had 15lbs ... Then after cranking the motor locked up ... Upon removing the spark plugs #6 cylinder was full of fuel ... Enough to lock the motor ?
What could cause # 6 to fill up with fuel ... I read there might be a defective vacume line in the fsm .... That ruptured causing the cylinder to fill with fuel ?
Any advice will help ... I have not removed the FSM yet ... But did check all injectors and the spray pattern is fine .... Thanks in advance ...
By davepnola in forum Technical DiscussionReplies: 2Last Post: 05-27-2017, 03:55 PM -
Off engine fuel filter for Verado 200hp
By billyfish in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 04-20-2017, 04:10 AM -
snow overload, time to really think of moving
By allpointsmarine in forum General Boating DiscussionReplies: 48Last Post: 02-25-2015, 07:02 PM -
Verado 350 sci - regular fuels with ethanol vs premium fuel without
By Toffen in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 6Last Post: 01-02-2012, 10:45 AM -
My new scarab w/verado , any upgrades on verado 250 ?
By cc@100mph in forum General Boating DiscussionReplies: 21Last Post: 08-03-2010, 06:28 AM
