Results 1 to 4 of 4
    Apr 2015
    Baltimore maryland
    Merc 280 midsection/water pump question.
    I recently bought a 280 mid section with a single ram to use with my worked 175 2.5l engine. This mid section has a 3/4" water tube and my original lower unit/water pump has a water pump housing for a smaller diameter tube. What water pump housing do I need to get in order for this thing to work?? New to performance outboard engines.. thanks!
    Jul 2004
    houston,tx
    late model cle and sportmaster gearcases have 3/4" water pump housings
    Apr 2015
    Baltimore maryland
    Would anyone happen to have the part number? I Also read you can modify the housing to a 3/4". anyone have any info on that?
    Moline,Ill
    Yes simple to cut off the 1/2" housing but you still need the sleeve and grommet for the 3/4" tube
    23-847685 sleeve
    26-88397 grommet
    The one on the left is a 1/2, right 3/4 and adapter (sleeve) for 3/4" tube
    And if you modify your housing, don't forget to take out the 1/2" grommet
    Oops, and drill out the housing to 3/4"
  5. Likes NICE PAIR liked this post
  1. water pump question
    By stivov1 in forum Technical Discussion
    Last Post: 08-06-2016, 09:14 AM
  2. Mercury Tech: Quick Water Pump Question - Merc 260
    By 951prerun in forum Technical Discussion
    Last Post: 04-30-2013, 07:31 AM
  3. Outboard jet pump & water pump seal question
    By jetriverfish in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-02-2012, 06:50 PM
  4. water pump question??
    By gorillapowered in forum Technical Discussion
    Last Post: 10-03-2011, 09:49 PM
  5. Merc water pump question
    By mrtlbeez in forum Technical Discussion
    Last Post: 07-06-2008, 03:40 PM
Simon Motorsports
