Results 1 to 4 of 4
    Jul 2012
    Huntington, Texas
    Bleed lines direct to fuel tank?
    I was browsing the archives the other day and read a post where it was suggested to run the bleed lines back to the fuel tank instead of to the crankcase. The guy that posted it has no recent activity and the post was from years ago. Just curious if anybody has experience with a setup like this?
    Apparently the primary crankcase pressure will push puddled fuel in the intake directly back to the fuel tank instead of dumping it into the crankcase. It's supposed to clean up the idle and off idle performance. Sounded plausible maybe, also maybe like a nightmare of tiny hoses running about everywhere!
    1981 Hydrostream Varmint - 1979 Mariner 175
    Florida Keys
    I tried it but it didn't seem to have enough crankcase pressure to push it all the way back to the tank.
    '95 STV "The Blue Goose"
    Top Speed 136mph (curtesy of Hurricane Irma 9/10/17)
  3. Thanks nitro_rat thanked for this post
    Nov 2004
    LEBANON OREGON
    ran a manifold setup to a return and it worked for midrange and that motor was overly cantankerous at idle so it made it POSSIBLE to shift it if needed and not be at 1300 in neutral but that was many years ago before I became a better tuner, now I just get out the jet kit and run the std bleed setup to minimize low speed fuel puddle
    Jul 2004
    houston,tx
    agree with above ,,,bleeders are to pull out the puddled fuel in intake for idling,,,,
    good tune and idle all day long,,,,with no bog on the hit
  1. Replies: 2
    Last Post: 08-12-2014, 09:28 PM
  2. Best tubing for bleed lines/small fuel lines 2.4 MERC
    By rujr in forum Technical Discussion
    Last Post: 07-10-2013, 10:26 AM
  3. fuel bleed lines
    By baycrabber1 in forum Technical Discussion
    Last Post: 03-27-2012, 03:00 PM
Mazco
