Results 1 to 15 of 18
04-20-2017, 08:26 PM #1
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
1998 Merc 200 EFI - Basic Rigging and Tune Up
Whats up Scream and Fly
Rigging an outboard for the first time.. got a couple basic questions
On mercury 10 pin cable, brown/white and tan/white wires.. trim & temp signals? which is which?
Center of first pic, white tee in vertical water line along stbd. head .. what would that be for?
There is a tube present from lower unit for water pressure.
2nd and 3rd pics.. starboard side forward of starter.. looking at Brass barbs..
Oil lines go to upper and lower barbs? whats the extra barb for up top?
and dumb question but worth asking.. does it matter which oil hose goes to each barb?
Thanks,
04-22-2017, 11:12 AM #2
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
I'll answer as I figure it out I guess in case it helps someone else...
One oil line has a blue stripe, the other does not so I'm going to take that as yes it matters which goes to each barb.
On the oil tank the hoses plug in one high, one low, so that's how I'm putting them on the motor.
04-22-2017, 11:37 AM #3
Screaming And Flying!
- 6,982
- 67
- 220
- 788
- 1475
Usually the blue stripe is air. As in sky (air) is blue. It goes to the pulse fitting on the star side low on the engine. On the tanks cap the air barb is the one without the pickup on it.....Brown /wht is for trim signal. Tanwhite is for temp signal. The white t is for a water pressure gauge. The brass t is the oil inj hookup, use the side barb. One going down is a pressure relief that is not used.
83 V-King, Mercury 2.5 200 EFI
http://www.youtube.com/user/Snookdude87#p/u/4/eO31kWjk0cc
NeedOne thanked for this post
04-22-2017, 11:41 AM #4
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
04-22-2017, 11:44 AM #5
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
On the wiring.. Im calling tan/wht temp cause it goes up on top the head
Brown/wht goes under motor so trim
I'm nervous to work on this but it seems all common sense. Im about to just jump in and get it done
04-22-2017, 12:01 PM #6
- 6,982
- 67
- 220
- 788
- 1475
Purple is key on power, red is always hot. As usual black is ground. yellow w/red stripe is start circuit. It's no biggie...Just do it, you will be an expert in no time...
04-24-2017, 06:02 AM #7
if you dont have a factory manual,get one,they are an invaluable tool for diagnosing issues.
wildnphx liked this post
04-26-2017, 05:03 PM #8
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
Agreed I need to get a manual..
Until I get my hands on one.. another question:
I have loosened the manual trim release screw and trimmed up with a hoist.
Manual screw tightened back down, lower hoist, motor does not stay in place, it drops..
Trim fluid needs topped off?
Could this indicate anything worse?
Thanks
04-27-2017, 05:14 PM #9
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
get all rams fully extended, fill, cycle up/down, repeat. done
04-28-2017, 05:00 AM #10
04-28-2017, 05:27 AM #11
I'd love one too tombahr1@aol.com Thanks in advance!!
Tom
04-29-2017, 06:00 PM #12
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
05-07-2017, 09:02 AM #13
Team Member
- Jun 2014
- Columbus, OH
- 58
- 10
- 18
Driveway shakedown today..
Can someone confirm: 3 beeps at key on position is the correct test tone for this motor?
05-07-2017, 07:31 PM #14
- 6,982
- 67
- 220
- 788
- 1475
System test is 3 quick beeps when key is turned on.
05-09-2017, 04:43 PM #15
1998 merc. 2.5 175
By mirage101 in forum Parts WantedReplies: 4Last Post: 07-17-2015, 12:46 AM -
1998 johnson 225 cowling for rigging
By bsullivan403 in forum Technical DiscussionReplies: 0Last Post: 08-22-2010, 10:01 AM -
Noob: Motor Tune VS Prop question 2.0 merc
By grendle in forum Technical DiscussionReplies: 4Last Post: 02-06-2010, 11:37 PM -
Basic Question: What's the difference between L6 and V6 Merc LU's?
By ShorePounder in forum Technical DiscussionReplies: 10Last Post: 03-01-2002, 06:18 PM
