Results 1 to 15 of 18
    Jun 2014
    Columbus, OH
    1998 Merc 200 EFI - Basic Rigging and Tune Up
    Whats up Scream and Fly
    Rigging an outboard for the first time.. got a couple basic questions
    On mercury 10 pin cable, brown/white and tan/white wires.. trim & temp signals? which is which?
    Center of first pic, white tee in vertical water line along stbd. head .. what would that be for?
    There is a tube present from lower unit for water pressure.
    2nd and 3rd pics.. starboard side forward of starter.. looking at Brass barbs..
    Oil lines go to upper and lower barbs? whats the extra barb for up top?
    and dumb question but worth asking.. does it matter which oil hose goes to each barb?
    Thanks,
ID:	373148   Click image for larger version.
ID:	373149   Click image for larger version.
    Jun 2014
    Columbus, OH
    I'll answer as I figure it out I guess in case it helps someone else...
    One oil line has a blue stripe, the other does not so I'm going to take that as yes it matters which goes to each barb.
    On the oil tank the hoses plug in one high, one low, so that's how I'm putting them on the motor.
    Usually the blue stripe is air. As in sky (air) is blue. It goes to the pulse fitting on the star side low on the engine. On the tanks cap the air barb is the one without the pickup on it.....Brown /wht is for trim signal. Tanwhite is for temp signal. The white t is for a water pressure gauge. The brass t is the oil inj hookup, use the side barb. One going down is a pressure relief that is not used.
  4. Thanks NeedOne thanked for this post
    Jun 2014
    Columbus, OH
    Man you got all the info I need, Thanks
    Jun 2014
    Columbus, OH
    On the wiring.. Im calling tan/wht temp cause it goes up on top the head
    Brown/wht goes under motor so trim
    I'm nervous to work on this but it seems all common sense. Im about to just jump in and get it done
    Purple is key on power, red is always hot. As usual black is ground. yellow w/red stripe is start circuit. It's no biggie...Just do it, you will be an expert in no time...
    Feb 2013
    mt holly,nc
    if you dont have a factory manual,get one,they are an invaluable tool for diagnosing issues.
  9. Likes wildnphx liked this post
    Jun 2014
    Columbus, OH
    Agreed I need to get a manual..
    Until I get my hands on one.. another question:
    I have loosened the manual trim release screw and trimmed up with a hoist.
    Manual screw tightened back down, lower hoist, motor does not stay in place, it drops..
    Trim fluid needs topped off?
    Could this indicate anything worse?
    Thanks
    Jun 2014
    Columbus, OH
    get all rams fully extended, fill, cycle up/down, repeat. done
    TX......somewhere?
    Quote Originally Posted by NeedOne View Post
    Until I get my hands on one.. Thanks
    send email add. i'll send ya pdf manual............
  13. Likes wildnphx liked this post
  14. #11
    Jul 2007
    Naples, Fl/Lake Hartwell, SC
    I'd love one too tombahr1@aol.com Thanks in advance!!
    Tom
    Jun 2014
    Columbus, OH
    Pm'ed thanks man
  16. #13
    Jun 2014
    Columbus, OH
    Driveway shakedown today..
    Can someone confirm: 3 beeps at key on position is the correct test tone for this motor?
  17. #14
    TX......somewhere?
    Quote Originally Posted by wetsetmarine View Post
    Tom
    jus saw tha post... let me know if ya got 'em.
  1. 1998 merc. 2.5 175
    By mirage101 in forum Parts Wanted
    Last Post: 07-17-2015, 12:46 AM
  2. 1998 johnson 225 cowling for rigging
    By bsullivan403 in forum Technical Discussion
    Last Post: 08-22-2010, 10:01 AM
  3. Noob: Motor Tune VS Prop question 2.0 merc
    By grendle in forum Technical Discussion
    Last Post: 02-06-2010, 11:37 PM
  4. Basic Question: What's the difference between L6 and V6 Merc LU's?
    By ShorePounder in forum Technical Discussion
    Last Post: 03-01-2002, 06:18 PM
