Results 1 to 3 of 3
    ar
    Mercury Xr6 water pressure and alarm help
    I have a 2004 merxury Xr6. Replaced water pump about a month ago and I have Had the motor off to swap exhaust recently. My buzzer started going off this weekend 3rd trip on new water pump. Psi shows around 10 when running around 4 at idle. Just checked my thermostats and they are missing. What do I need to look for or what did I tear up when I removed the motor lol. Please help.
    Mar 2011
    Virginia
    Check the gommet/seals on each end of the water tube are there. Especially the one the goes in the pump end. If the water tube was removed( or fell out) check the top one as well.
    Go Time
    26 Regulator twin 250 EFI
    Baton Rouge, La
    What's where the thermostat s should be? Mike
    Cheaters never Win !!!
  1. 200 mercury water pressure
    By skatermike24 in forum Technical Discussion
    Last Post: 09-14-2023, 10:56 AM
  2. No water pressure alarm
    By unknown1 in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 10-25-2016, 06:57 PM
  3. Mercury 2.5l and water pressure
    By fierodough in forum Technical Discussion
    Last Post: 07-11-2014, 01:35 PM
  4. Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
    By sasquitch in forum Technical Discussion
    Last Post: 07-31-2010, 09:16 PM
