Results 46 to 56 of 56
05-08-2017, 09:45 PM #46
Make sure all your ground wires are good.
05-09-2017, 02:48 AM #47Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
did anyone mention the right flywheel for the timer base?
05-09-2017, 06:32 AM #48Member
- May 2009
- Ohio
- 52
Don't guess i follow. Here is the timer base I used...
http://www.iboats.com/Johnson-Evinru...view_id.335766
05-09-2017, 06:59 AM #49Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
05-09-2017, 09:02 PM #50Member
- May 2009
- Ohio
- 52
Couple of questions. Should I be checking the spark using the starter or should I be checking it with it running? Secondly, could the stator be causing the problems in having?It's the only ignition part other than the rectifier and coils I haven't changed.
05-09-2017, 09:08 PM #51
Are all the flywheel magnets tight and evenly spaced?
05-09-2017, 09:22 PM #52Member
- May 2009
- Ohio
- 52
05-10-2017, 08:05 AM #53Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
CDI has the center hub arrangement to verify you have the correct flywheel or that hub has not moved. Engine needs to be running to properly check timing and make sure timing lead is clear of all cylinders on engine except the one you are checking. Stator will not cause timing to be off, it can cause weak or lack of spark.
05-11-2017, 08:59 AM #54Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
02-21-2018, 10:30 AM #55Member
- May 2009
- Ohio
- 52
Sorry to revive my old thread. Still chasing this demon. A little catch up... Got the motor going again. Broke it in, but started looking like it was going down the same road it did before regarding lean... Ive taken the entire front half apart and I came across something. I found a rip in the gasket in the (side) of the throttle body On that hole that feeds the suspect cylinder. I know this cant be good, but would it cause a lean condition on this cylinder?
New gasket on left
02-21-2018, 04:49 PM #56
better do all of them, the black gaskets are not good with gasahol.............
merc 2.5 piston wash pics, rich or lean??
By superboattwin250 in forum Technical DiscussionReplies: 10Last Post: 01-30-2015, 06:49 PM -
1997 Johnson Venom 225 3.0 Looper
By cdoliver in forum Technical DiscussionReplies: 11Last Post: 06-20-2014, 10:15 PM -
Piston tops, what do i look for if to lean?
By FAST-J in forum Technical DiscussionReplies: 13Last Post: 04-24-2007, 04:29 PM -
omc looper gurus! v6 lean sneezing
By baja200merk in forum Technical DiscussionReplies: 19Last Post: 07-26-2006, 07:01 AM -
Lean piston color
By jody in forum Technical DiscussionReplies: 6Last Post: 04-16-2002, 01:47 PM
