Results 31 to 45 of 56
04-23-2017, 07:32 AM #31Member
- May 2009
- Ohio
- 52
If anyone can tell me the difference between those two sleeves, I'd appreciate that. I'm about to check the reeds, but If that sleeve won't work, I'm going to take it back to the rebuilder and have them replace the sleeve... what a pain...
04-23-2017, 07:48 AM #32Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I just looked at the photo of the sleeves and noticed they are for v6 and v8
That says it all
I dont think there has ever been a sleeve thats the same for v6 and v8?
Only chance was 2.7 v6 and 3.6 v8
04-23-2017, 07:51 AM #33Member
- May 2009
- Ohio
- 52
04-23-2017, 08:04 AM #34Member
- May 2009
- Ohio
- 52
04-23-2017, 08:18 AM #35
Not familiar with omc. If it has a flat floor and the bridge isn't blocking or restricting flow shouldn't be a problem as long as the heights of the openings are the same and port timing is the same as the rest. Looks like it may just be there for extra support, but again not sure because not familiar with omc.
04-23-2017, 09:01 AM #36Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
what brand sleeve did they put in your engine?
04-23-2017, 09:08 AM #37Member
- May 2009
- Ohio
- 52
No indication of brand on my receipt. I did measure all of the port sizes and Heights before reinstalling. They were the same. the only difference is where that bridge on the bottom and it didn't have an exhaust relief hole
04-23-2017, 10:03 AM #38Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
That bridge on the bottom would go right across the bottom of the boost port and should have been removed. The small bore had them but sleeves were longer. Non come with idle relief in they are machined in after sleeve is installed.
Did you clean piston top to verify it was installed correctly?
04-23-2017, 10:21 AM #39Member
- May 2009
- Ohio
- 52
04-24-2017, 06:45 PM #40Member
- May 2009
- Ohio
- 52
Anyone know if that bridge over the boost port is causing my lean condition or should I look elsewhere? Sorry again for the rookie questions.
04-26-2017, 03:24 PM #41Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
I doubt it is causing your lean condition but will hurt power. You need to index flywheel to check timing on each cylinder. Did you check the water dividers?
05-02-2017, 05:34 PM #42Member
- May 2009
- Ohio
- 52
Well I finally got around d to indexing the flywheel and low and behold the #2 cylinder is retarded about 8deg... all others are advanced approx 10deg. So... what fixes this problem? I should have listened to you earlier... it's not the pack, it's a brand new OMC pack. And the old pack does the same thing... thanks again
05-02-2017, 05:59 PM #43Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
If both packs are giving you the same timing issue you will need to replace the timer base. have you tried grounding the white with black tracer that comes out of the pack and goes to the port temp switch? If not do this to make sure engine is not in quick start when you check timing.
05-02-2017, 06:11 PM #44Member
- May 2009
- Ohio
- 52
05-08-2017, 08:47 PM #45Member
- May 2009
- Ohio
- 52
Well installed new timer base and I'm not sold it's fixed... now some cyl. Are dead on and some are off. Sometimes I get a good reading then the timing mark jumps over an inch after a few revolutions.... mostly happens on cyl 1 and 4... What do i need to do now? I put the old pack on with same results... I'm lost...
merc 2.5 piston wash pics, rich or lean??
By superboattwin250 in forum Technical DiscussionReplies: 10Last Post: 01-30-2015, 06:49 PM -
1997 Johnson Venom 225 3.0 Looper
By cdoliver in forum Technical DiscussionReplies: 11Last Post: 06-20-2014, 10:15 PM -
Piston tops, what do i look for if to lean?
By FAST-J in forum Technical DiscussionReplies: 13Last Post: 04-24-2007, 04:29 PM -
omc looper gurus! v6 lean sneezing
By baja200merk in forum Technical DiscussionReplies: 19Last Post: 07-26-2006, 07:01 AM -
Lean piston color
By jody in forum Technical DiscussionReplies: 6Last Post: 04-16-2002, 01:47 PM
