Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 56 of 56
  1. #46
    May 2002
    Lake Havasu City AZ
    Make sure all your ground wires are good.
  2. #47
    8 Post(s)
    did anyone mention the right flywheel for the timer base?
  3. #48
    May 2009
    Ohio
    Don't guess i follow. Here is the timer base I used...
    http://www.iboats.com/Johnson-Evinru...view_id.335766
  4. #49
    8 Post(s)
    Quote Originally Posted by cdoliver View Post
    Unless you have owned it from new you need to check the flywheel matches your timer base
  5. #50
    May 2009
    Ohio
    Couple of questions. Should I be checking the spark using the starter or should I be checking it with it running? Secondly, could the stator be causing the problems in having?It's the only ignition part other than the rectifier and coils I haven't changed.
  6. #51
    Ft. Lauderdale, Fl
    Are all the flywheel magnets tight and evenly spaced?
  7. #52
    May 2009
    Ohio
    Quote Originally Posted by flabum1017 View Post
    Yes they are, but I'll check again. Thanks
  8. #53
    May 2001
    Hickory NC
    CDI has the center hub arrangement to verify you have the correct flywheel or that hub has not moved. Engine needs to be running to properly check timing and make sure timing lead is clear of all cylinders on engine except the one you are checking. Stator will not cause timing to be off, it can cause weak or lack of spark.
  9. #54
    8 Post(s)
    how do you recognise a ccw flywheel
  10. #55
    May 2009
    Ohio
    Sorry to revive my old thread. Still chasing this demon. A little catch up... Got the motor going again. Broke it in, but started looking like it was going down the same road it did before regarding lean... Ive taken the entire front half apart and I came across something. I found a rip in the gasket in the (side) of the throttle body On that hole that feeds the suspect cylinder. I know this cant be good, but would it cause a lean condition on this cylinder?
    New gasket on leftClick image for larger version.
  11. #56
    Ft. Lauderdale, Fl
    better do all of them, the black gaskets are not good with gasahol.............
  1. merc 2.5 piston wash pics, rich or lean??
    By superboattwin250 in forum Technical Discussion
    Last Post: 01-30-2015, 06:49 PM
  2. 1997 Johnson Venom 225 3.0 Looper
    By cdoliver in forum Technical Discussion
    Last Post: 06-20-2014, 10:15 PM
  3. Piston tops, what do i look for if to lean?
    By FAST-J in forum Technical Discussion
    Last Post: 04-24-2007, 04:29 PM
  4. omc looper gurus! v6 lean sneezing
    By baja200merk in forum Technical Discussion
    Last Post: 07-26-2006, 07:01 AM
  5. Lean piston color
    By jody in forum Technical Discussion
    Last Post: 04-16-2002, 01:47 PM
