Results 1 to 15 of 56
04-07-2017, 09:56 AM #1Member
- May 2009
- Ohio
- 52
1997 225 looper new piston, lean or hot?
Hello,
I had a failure of #2 (lost ring locator) had it resleeved, new piston and new rings all the way around.
Now just before the failure I changed the water pump, thermostats, and plugged the idle relief holes... my mistake was not rejetting after plugging the holes.
Now after the rebuild I have gone up 2 jet sizes (74d) in all the holes (i cleaned up all the ports and casting flaws and added cc reeds) and 4 (76d) in the #2 hole.
I have 120psi in all the holes.
I have followed the break in procedure with double oil.
My question is: when checking the piston tops all the other pistons are very wet but #2 is totally dry and almost looks like it's running warm? All spark plugs are chocolate brown.
What should I check?
Thanks
04-07-2017, 06:31 PM #2Member
- May 2009
- Ohio
- 52
04-08-2017, 01:02 PM #3
problem is there's three stages of plug wash check-idle-mid-top end,if its leaning out at mid to top,hard to tell without holding at 3000 rpm for 1 min.then check n then 6000 for 1 min. then check.then if its building up at idle u almost need to run at 3000 for 2min.and then 6000 for 2 min.to get an accurate reading,best way is to start rich on all 2 stages of rpm then lean down from there,i know its a pain and expensive going through 2 sets of each size jet for mid and top end,but unfortunately its the only way,most of itll be how it runs throughout the process.
04-09-2017, 05:28 AM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Post a photo of the piston top it may be washed clean.
04-09-2017, 09:11 PM #5
Should have replaced the other 5 pistons as if one fails the others will soon follow...did you do water mod to block??? Need to index flywheel and see if #2 is firing correctly..could be timer base or flywheel magnets..
04-10-2017, 02:21 PM #6
04-17-2017, 12:42 PM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Not being as smart ass the flow pattern across the piston tells a lot about what is happening. Plug is not showing a lot of heat depending on rpm when you chopped throttle. I too would have replaced all 6. Degree flywheel and check timing on each. Magnets don't cause an issue on 1 cylinder but are easy to check. Number 2 is the hottest running cylinder on that block but if you are up 4 sizes from stock should be good unless you ground some angles wrong.
FORBESAUTO, pointer liked this post
04-17-2017, 06:33 PM #8
Is that the block they had with the flaw in it that would wet a cylinder?
04-17-2017, 08:56 PM #9
Sorry,I posted something (way back 08'ish)about my pistons being washed clean like there was to much fuel. Anyways not trying to start a controversy with al,with him I'd be all ears instead,which is EXTREMELY rare for bigbore.
04-17-2017, 08:58 PM #10Member
- May 2009
- Ohio
- 52
Sorry for the delay. I'll have pics tomorrow of the piston tops after wot for 1 min
04-18-2017, 07:14 AM #11Member
- May 2009
- Ohio
- 52
04-18-2017, 07:17 AM #12Member
- May 2009
- Ohio
- 52
04-18-2017, 07:21 AM #13Member
- May 2009
- Ohio
- 52
04-18-2017, 07:35 AM #14Member
- May 2009
- Ohio
- 52
04-18-2017, 08:20 AM #15Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
2 Is lean you need to check carb and timing on number 2. I would also check to make sure you dont have a double fire. Did you install factory jets or did you drill the original? D series? Water temp? I would not be using that silicone, clean dry surface for factory head gasket.
merc 2.5 piston wash pics, rich or lean??
By superboattwin250 in forum Technical DiscussionReplies: 10Last Post: 01-30-2015, 06:49 PM -
1997 Johnson Venom 225 3.0 Looper
By cdoliver in forum Technical DiscussionReplies: 11Last Post: 06-20-2014, 10:15 PM -
Piston tops, what do i look for if to lean?
By FAST-J in forum Technical DiscussionReplies: 13Last Post: 04-24-2007, 04:29 PM -
omc looper gurus! v6 lean sneezing
By baja200merk in forum Technical DiscussionReplies: 19Last Post: 07-26-2006, 07:01 AM -
Lean piston color
By jody in forum Technical DiscussionReplies: 6Last Post: 04-16-2002, 01:47 PM
