Results 1 to 15 of 15
    Jul 2001
    Latvia
    Evinrude FICHT 175 (98 y.m.) Ignition module circuit. Repaired.
    May be someone would relieve 20 Years most kept secret - ignition module internal circuit drawing (schematics). Understand, that on previous OMC mistakes some companies still doing millions profit (repair $ 500-800). Thank You in advance!
    DZK Boats. Small Mahogany runabouts.
  2. Thanks billfinis thanked for this post
    Jul 2001
    Latvia
    Here is instruction how to fix problem - no spark. Change big yellow capacitor. Capacitor costs $2, time to repair 1-2 hours. Save $400.Click image for larger version.
ID:	372859Click image for larger version.
ID:	372860Click image for larger version.
ID:	372861Click image for larger version.
ID:	372862Click image for larger version.
  4. Likes billfinis liked this post
  5. #3
    Jul 2001
    Latvia
    The previous repair would last 50+ hours, but if You want forget about problem add ceramic capacitor from 1000 pf, same voltage, parallel to plastic one and forget about repair at all.
  6. Thanks thehydes thanked for this post
  7. #4
    May 2018
    Ohio
    Quote Originally Posted by Dzintars View Post
    How do you safely remove the compound around the capacitor?
    Jul 2018
    arkansas
    Ignition Module 98' Ficht
    Who can rebuild the ignition modules for these motors? 1998 150 Ficht
    May 2008
    Ottawa, Canada
    Quote Originally Posted by js547103 View Post
    I have started to do this repair on my part 0586381 (replaces 0586308).
    I see the same yellow cap. I had to drill out the 4 aluminum stand-offs to remove the frame.
    To break down the potting compound I soaked the area near the cap in kerosene and it made it easier to pick.
    I am about to solder in a ceramic 1000pF 500v cap. but now wonder about re-assembly? Those stand-offs that I drilled may be required for grounding? There is a connector pin that seems to be ground when checking with my meter. Anyone else do this fix and have success? What did you do about the drilled stand-offs?
    May 2008
    Ottawa, Canada
    Quote Originally Posted by thehydes View Post
    Prior to trying this fix, I had a faint spark. Now I have no spark at all.
    I suspect the stand-offs carry connection to ground.
    I also wonder if 1000pF will work for my cap?
    Next I will try and repair the connection to the standoffs and put a new 0.68MF cap in.
    May 2019
    San Giego,CA
    Did you succeed?
    Hi thehydes,
    Did you succeed in repairing the ignition module? How did you do it?
    I had to replace mine on Evinrude 175HP Ficht. I want to repair the removed one and keep it as spare.
    Thanks.
    May 2008
    Ottawa, Canada
    No fix
    Quote Originally Posted by Bootman View Post
    Hi thehydes,
    Thanks.
    I never did. Bought one on eBay
    May 2019
    San Giego,CA
    Thanks.
    Ok, thanks.
    I will have the unit repaired by one of the companies that do this work: $450 is the cost.
    They have the market, good for them, the units are not available anymore.
    Safe boating.
  14. #11
    May 2008
    Ottawa, Canada
    Ok, thanks.
    Safe boating.
    Thanks, BTW there is one on EBay now.
    https://www.ebay.com/itm/Evinrude-fi...AAAOSw7ttcZsyX
    Jun 2020
    Greece
    Cool How to open the module safely!!
    Dzintars solution worked perfecty for me. I also have a way to safely open the module without damaging it (no metal posts drilled). Since this is an old thread I will not post the solution, because it is a bit leangthy, unless someone asks for it. All props to Dzintars by the way, since he was the reason I could repair two modules for my self. All I did was figure out a way to make it easier.
  16. #13
    May 2008
    Ottawa, Canada
    Quote Originally Posted by billfinis View Post
    Really great news. I still have my broken one and would like to repair it if possible. Perhaps a YouTube video would make your lengthy explanation easier? I would appreciate your solution, thank you.
  17. #14
    Jun 2020
    Greece
    It is not very easy to create a youtube video since I don't have a broken power pack for now in order to illustrate the points I want but I will try to create a pdf with steps. It might take some time though because I am currently studing for my summer exams in university.
  18. Thanks thehydes thanked for this post
  19. #15
    Jun 2020
    Greece
    Complete repaire quide for ignition module
    Ok the repair guide is here!!! Make sure you read it carefully before starting to repair your module. For any questions don't hesitate to ask!!
    Attached Files Attached Files
  20. Thanks thehydes, PJPNO thanked for this post
  1. 225 EFI Ignition module
    By strongback in forum Misc. Parts and Accessories
    Last Post: 09-03-2014, 09:04 PM
  2. FICHT/Evinrude Power to Ignition Switch Issue
    By rbaklini in forum Technical Discussion
    Last Post: 03-20-2009, 07:50 AM
  3. 2.5 Ignition module
    By CNT in forum Technical Discussion
    Last Post: 03-30-2005, 03:08 PM
  4. Ignition circuit? and others.
    By Techno in forum Electronics, Audio Systems, and Wiring
    Last Post: 06-22-2004, 09:59 PM
