Results 1 to 4 of 4
Thread: Oil pump drive gear
04-04-2017, 05:52 PM #1Member
- Oct 2006
- Chandler AZ
- 83
Oil pump drive gear
On a 2.5 200 hp that I'm going to premix can I eliminate the oil pump friar gear from crank? Or do I still need it on the crank?
04-04-2017, 06:29 PM #2
Leave it on crank to take up space to keep correct ccs in crankcase. Make sure to use block off plug to hold bushing in place.
04-04-2017, 06:33 PM #3
Or you can remove bushing and fill in hole, oil pump void, pump mounting hole, and fill in crankcase where gear goes with epoxy. But thats another topic and a lot of work
04-05-2017, 03:35 PM #4
early mod vp gear case (cle) with drive shaft
By Gilles1 in forum Lower UnitsReplies: 1Last Post: 12-11-2014, 06:22 PM -
Drive gear for 2.4 merc
By Quinten in forum Parts WantedReplies: 3Last Post: 07-08-2013, 06:41 PM
