Results 46 to 60 of 115
Thread: CRT motor
02-26-2019, 12:38 PM #46
02-26-2019, 08:22 PM #47
It's for sale right now and the reason for confusion in price is simple...when you and Joe blow up the street order a Yamaha or a mercury or and evinrude you both get the same motor... When you get a CRT it is truly a custom engine with options on cranks, rods, pistons, horn or svs style intake, Many different reed options ..compression options. Can buy one set up for alcohol race gas or pump gas with the correct curves to match. And now even a different ignition option to do away with old school electronics. So if you are serious about actually buying on contact Matthew and decide if you want a base engine or you want one with all the bells and whistles....Again your engine will be custom to your needs if you want it for drag racing or a twin engine cat or it you wanna put in in a sand rail. There has been countless hours of r and d and went thru 8 generations of engines before we decided it was the best that we can produce. Thank you hope this helps. Again if you're serious contact Matthew
caldwellrace thanked for this post
02-26-2019, 09:32 PM #48
5000 RPM
- Feb 2010
- Ringwood, IL
- 384
- 19
Very well said Michael!!!!
Christopher Alby
President and Owner of the NIDBA
www.nidba.net
Triad DR20 (Last one made by Walley) - Merc Mod 280 by Caldwell - CRT coming in 2018
STV ModVP New in 1992 - Merc Mod with Nitrous coming in 2018
02-26-2019, 09:36 PM #49
Can't complain about getting a price if you don't call and ask
'84 Checkmate Convincor
Twin v6 closed deck Evinrude loopers
Heavily ported,2.7 heads,cooling mods
milled finger ported to match vertex pistons,
All casting slag removed
Sleeves in opposite so no idle reliefs
drilled/relieved exh, lower and mid,
148 psi comp,balanced pistons and rods, Holley red,Stuffed,77d jets 106 pullovers
CDI 8500 digital ignitions ..Boyesen reeds..And more....
02-26-2019, 10:16 PM #50
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 6,985
- 526
- 209
- 2052
- 914
- 4 Post(s)
How many can they sell before they fall under epa regs?
02-26-2019, 10:46 PM #51
How many motors can GM, Ford and Mopar sell out of their Hi Po catalogs?
Michael J Giesler liked this post
02-26-2019, 11:21 PM #52
- Jun 2007
- 6,985
- 526
- 209
- 2052
- 914
- 4 Post(s)
02-27-2019, 12:29 AM #53
That does not look like a replacement part.. let's not be obtuse.
02-27-2019, 12:34 AM #54
- Jun 2007
- 6,985
- 526
- 209
- 2052
- 914
- 4 Post(s)
02-27-2019, 12:44 AM #55
Who cares? After you hand them the loot you can put it in anything you want, a black helicopter and a fleet of tinted window suburbans won't follow you home.
Glasstream15 liked this post
02-27-2019, 06:43 AM #56
02-27-2019, 07:13 AM #57
Funny thing about dynos, They don`t tell the whole story. We aren`t racing dynos anyway. I drove a guys 707hp new car and he bragged about the dyno hp but let me tell you, It did not feel like those old LS-6 big blocks in 1970 that only made 450hp and would pin your back side to the seat.
02-27-2019, 08:43 AM #58
The good SAE approved ones will tell the whole story, theres a reason every respectable tuner in the world uses them including Mercury. Even if they are not SAE they still can be used as a tuning tool we have been surprised a few times (good and bad).
Z06man liked this post
02-27-2019, 09:05 AM #59
02-27-2019, 10:28 AM #60
And shut the factory hood
mrichartz liked this post
what is the fastest 2.0merc you have had, race motor or fishing motor v bottom please
By aaron78viper in forum General Boating DiscussionReplies: 29Last Post: 12-29-2016, 10:36 PM -
Those of you with decent setup: how much speed/rpm do you gain motor down vs motor up
By coreyc619 in forum Props, Setup, and RiggingReplies: 11Last Post: 08-05-2015, 06:45 PM -
Converting a 91 chevy truck to Hot Rod Motor carb motor need advise !
By Jay Smith in forum General Boating DiscussionReplies: 20Last Post: 11-29-2001, 10:45 PM
