Results 1 to 2 of 2
    Jun 2001
    Beulaville North Carolina
    hydraulic sterring help
    I am in the process of changing to hydraulic..my question is the bulkhead pigtail fitting part # HF5516 will it fit over hoses that already have fittings on each end like you would buy in a kit or do they have to be put on before brass fittings are put on
    thanks Gary
    Jul 2011
    Gloucester, VA
    Before the ends are put on. If you don't have your hoses yet you can order them already on the length you need.
  1. hydraulic sterring
    By upyours in forum General Boating Discussion
    Last Post: 12-26-2013, 11:20 PM
  2. Hydraulic sterring clearance with power lift?
    By frank_a in forum Props, Setup, and Rigging
    Last Post: 05-14-2012, 02:00 PM
  3. Mercury Tech: Hydraulic sterring clearance with power lift on vintage in-line?
    By frank_a in forum Technical Discussion
    Last Post: 05-13-2012, 07:03 PM
  4. which brand of hydraulic sterring is best?
    By Daystreamer in forum General Boating Discussion
    Last Post: 09-10-2007, 05:40 AM
