Results 1 to 2 of 2
03-22-2017, 01:19 PM #15000 RPM
- Mar 2009
- Florida
- 227
1996 evinrude 150 intruder questions..
I just bought a 1996 evinrude 150 intruder. Its a carb motor. The carbs seem to be seaping a small amout of gas around the float bowl. Not alot but do I need to replace the bowls ? The compression is around 115 on all cyliners. I have it on a18' ranger bass boat. I took it out today and it seems to run fine. Just wanted some opinions on the motor.
03-22-2017, 01:34 PM #25000 RPM
- Mar 2009
- Florida
- 227
I just did a search and found lots of info on this motor . I will rebuild the carbs and get new float bowls. Any other info is appreciated. Thanks
Evinrude Intruder 150
By Circlem in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 12-13-2015, 05:01 PM -
94 evinrude intruder 150 bogging
By gannon311 in forum Technical DiscussionReplies: 12Last Post: 03-31-2013, 02:14 PM -
175 Evinrude Intruder Problems
By jeepster21 in forum Technical DiscussionReplies: 7Last Post: 05-18-2009, 08:34 PM -
OMC Tech: evinrude intruder
By patchesII in forum Technical DiscussionReplies: 12Last Post: 06-21-2008, 09:50 AM -
What Is Involved In Converting An Evinrude 150 Intruder Into A 175 Intruder?
By TNFISHRMAN in forum Technical DiscussionReplies: 18Last Post: 10-19-2003, 10:12 PM
