Results 1 to 5 of 5
Thread: Adjusting pulley cable steering
03-20-2017, 04:04 PM #1
How tight should this be?
Mine seems loose after we adjusted it , it's a bear to try and hold the steering straight and pull the cable tight and tighten down the clamp at same time.
This is is on an xr2001 with wing plates any tips would be appreciated!!
03-20-2017, 04:37 PM #2
5000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 537
- 18
- 86
- 76
I get my kid to hold the steering wheel straight and I tighten the cables and clamps.
its not difficult to get it tight, it's next to impossible to get tight with the wheel straight.
Michael J Giesler liked this post
03-20-2017, 05:37 PM #3
Platinum Team Member
- Jan 2013
- SE MN
- 863
- 44
- 145
- 60
That's what turnbuckles are for.
HStream1 liked this post
03-20-2017, 06:09 PM #4
03-20-2017, 08:41 PM #5
Lower the motor a little (maybe 1/2" or so), get it as tight as you can, then raise it back to where you want it. Alternatively....if you're running a 15" with the Alli wings, it probably won't maintain the same tightness while trimmed all the way down as it will at level or all the way up. Find where it is most loose and make that the point where you pull it tight. At a minimum, you want it tight enough so that you can't pinch the two cables (from pulley to anchor point) and make them touch.
90 5.0 thanked for this post
bullwhipjkg liked this post
STV cable-pulley steering
By Mo River Rat in forum Technical DiscussionReplies: 1Last Post: 04-07-2014, 12:30 PM -
Replacement cable for cable and pulley steering system
By GTRMick in forum Props, Setup, and RiggingReplies: 0Last Post: 12-09-2013, 07:11 PM -
Cable and Pulley steering
By rbengines in forum Props, Setup, and RiggingReplies: 10Last Post: 01-31-2012, 04:19 PM
