Results 1 to 15 of 18
03-13-2017, 09:13 AM #1
Opinions on older style trim pump for 2.5 merc...pic included
Got this pump along with a blown motor I bought for parts... wondering if it's worth keeping or should I get rid of it...everything works great, has new solenoids, new trim lines...no leaks etc...would be using it on a 2.5L carbed merc. Thanks.
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
03-14-2017, 06:37 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11035
Fresh fluid, and run it till it blows.....
03-14-2017, 09:07 AM #35000 RPM
- Aug 2007
- Gravenhurst, Ontario.
- 708
- 50
- 42
- 199
- 210
What he said.
those old pumps don't die.....or at least the 2 I've had wouldn't.
they aren't fast but they last.
Magcat 62 liked this post
03-14-2017, 09:15 AM #4
03-14-2017, 09:30 PM #5
I've used 'em for years! They can be run on 24v to speed'em up and work extremely well if you change the Pump to a Mercruiser pump.
Motor, bracket, can, etc. will all interchange but you jst need the pump itself!
Mercruiser Pump + 24v = Rock'n Roll!!!WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
03-14-2017, 10:30 PM #6
Great! Thanks for the input! I'll run it with my set up for now!
03-14-2017, 11:44 PM #7
03-15-2017, 12:03 PM #8The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 338
- 19220
- 3 Post(s)
03-15-2017, 12:04 PM #9
03-15-2017, 04:27 PM #10
Motorcycle fork oil. Easy to find and you can get lighter weight than atf. Mike
Cheaters never Win !!!
03-15-2017, 11:34 PM #11
Lighter the oil, quicker the Trim, less resistance?
03-16-2017, 07:39 AM #12
That's it!
Josh Peterson
03-16-2017, 09:55 AM #13
Yep like nitro said. Very noticeable difference compared to 30weight. Mike.
03-16-2017, 01:35 PM #14
Not just oil weight but check viscosity indexes at varying temps too.
One of the good things about aviation hydro fluid is it is designed not to have as much variation in viscosity index with temp changes as traditional "tractor" hydro fluid.
Less variation means more consistent trim timing
nitro_rat liked this post
03-16-2017, 04:11 PM #15
Good point !
